Broken Axle
Old Aug 7, 2011 | 08:29 AM
rjmij's Avatar
rjmij
Default Broken Axle
Drag racing at Hochenheimring Germany. Is this a difficult fix/change once I an able to get the parts here in Germany?
Old Aug 7, 2011 | 09:31 AM
bluez06ny's Avatar
bluez06ny
Looks like you need a new outer CV joint:
A big breaker bar to remove spindle nut, knuckle needs to come off ball joints (you might need ball joint tool), CV joint can be tapped off with block of wood and hammer. Probably want new CV boot and lube too.
Old Aug 7, 2011 | 09:36 AM
b4i4getit's Avatar
b4i4getit
I thought the axles on these cars were fairly robust. What kind of driving could cause this ?
Old Aug 7, 2011 | 09:41 AM
BornSUPERCHARGED's Avatar
BornSUPERCHARGED
Well there's no time like the present to upgrade to The Drive Shaft Shop's 1000hp parts
(you can click to enlarge)
I believe I've read people doing the swap in an hour or two in their garage.
Old Aug 7, 2011 | 09:44 AM
csnow's Avatar
csnow
I snapped mine in the same place. Takes 30 minutes to swap once you have the car on jacks. Mine was a combo of wheel hop and the fact the axle nut had loosened itself to only finger tight. Buy Z06 axles to replace them.
Old Aug 7, 2011 | 09:49 AM
erick_e's Avatar
erick_e
St. Jude Donor '13-'14-'15-'16
I read in another thread where someone mentioned that the axles were a weak link, in order to prevent differentials from breaking. Its 'much cheaper for the General to fix/replace an axle vs. a diff.
Anyways, its not a difficult job. PM me your email, and I will email you the removal/installation instructions.
Old Aug 7, 2011 | 09:50 AM
BornSUPERCHARGED
Did you make any adjustments to your setup to eliminate the wheel hop?
Originally Posted by erick_e
I read in another thread where someone mentioned that the axles were a weak link, in order to prevent differentials from breaking. Its 'much cheaper for teh General to fix/replace an axle vs. a diff.
That's why you upgrade it all
To Broken Axle
