Convertible top question
Old Aug 7, 2011 | 05:02 PM
easttnscott's Avatar
easttnscott
Default Convertible top question
When raising or lowering the top can you stop it by releasing the button about halfway to check the waterfall. I have some kind of small noise on the drivers side with the top up. The noise goes way when I reach behind the seat and put a little pressure against the waterfall.
Old Aug 7, 2011 | 05:18 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
yes, just release the button.
Old Aug 7, 2011 | 05:36 PM
lkelliott's Avatar
lkelliott
You can stop the button at any point and then go up or down after stopping. Raise the top until it is fully out of the way, then you can take all the time you need to check out the waterfall.
Kent
Canyon Run Videos
Old Aug 7, 2011 | 05:49 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
With the top stopped half-way open, the pump will eventually (10 minutes?) release the pressure and the top will drop.
This doesn't hurt anything but can catch you by surprise while you're working.
Prop it up if need be.
Old Aug 7, 2011 | 05:52 PM
1FASTVERT's Avatar
1FASTVERT
St. Jude Donor '12
What he said!!!!
Old Aug 7, 2011 | 06:03 PM
Sunnyvale Dave's Avatar
Sunnyvale Dave
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'19
I learned that the hard way.
Old Aug 7, 2011 | 06:26 PM
cclive's Avatar
cclive
If a finger were in near one of the hinge points, it could be much worse than just a surprise.
Old Aug 7, 2011 | 08:24 PM
cylon's Avatar
cylon
Does it sound like a rattle? I had a rattle and it turned out the joints were loose, either rivets or screws, i don't know which, gone now
Old Aug 7, 2011 | 10:11 PM
C7Joy's Avatar
C7Joy
You can pull the manual release "ripcord" under the passenger side of the waterfall and pull it up manually to check things out also....
Old Aug 8, 2011 | 07:20 PM
easttnscott
I did find a couple of loose screws and also sprayed some silicone on a few areas behind the speedster humps and drove it down the road it took care of the noise going to take a little trip tomorrow and see what happens. Thanks for helping.
To Convertible top question
