warning lights going nuts
Old Aug 8, 2011 | 10:38 AM
Harleydave's Avatar
Harleydave
Default warning lights going nuts
anyone have this problem? I have an 05 and when you have to climb a steep driveway or entrance way... and at the bottom (by the curb water drainage area) you approach at an agle (slowly..not to scrape front end) the computer warning lights go off....service anti lock brakes..service active handling...check traction system...lights stay on until you stop and re-start ignition. Once restarted they stay off.
appreciate any help....thanks
Harleydave
Old Aug 8, 2011 | 10:41 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Harleydave
The angle and steep drive are causing one of your wheels to slip while coming up the curb???
Elmer
