shifting to netural with a dead battery (automatic)
I have 2007 with an auto if the battery dies how do u shift it in to neutral to push it out to jump it.?
Yanking on the auto shifter snapped the cable causing damage to the shifter mechanism itself and got me a $1200 bill from the dealer and 10 days without my ride.
I can comment on this one with first hand experience. Bought my 06 A6 new in April of 06. About 4 months later went out to the garage to take the car out and couldn't open the doors. To shorten the story I got in using the key/open the back hatch method and started trying all the electrical systems. Nothing I tried worked execpt the horn. The only way I could think of to get the car out of park and push it out of the garage was to go under it to the transaxle area and disconnect the linkage, a tight fit for me as I am not what would be called a small framed peson. Fortunately the flatbed rig was able to back up to my garage door and pull the car onto the bed. I didn't like the idea of the rear tires sliding across a few feet of garage floor and driveway and up the steel bed, not so much for tire wear concerns as to just the strain on the parking pawl and asscoiated parts in the transmission. Maybe I worry too much about such things but my solution was to get a couple bottles of dish washing liquid from the pantry and "grease" the concrete and steel truck bed behind the tires as the car was being pulled aboard. The truck operator might of thought I was a bit strange but it was my car and driveway. It went tho the dealer and took a few extra hands to get it off of the truck and into a service bay.
It turned our to be a dead BCM, the computer located under the passenger side floor. It was replaced under warranty and no more problems with it yet.
I looked at the wiring diagrams in my service manual later and found that nearly every electrical component in the car is dependent upon that BCM in some way, time delays, iinterlock with other circuits, etc.
One exception i found was the horn. For some reason the engineeers left the horn function to be a stand alone circuit, operating through a horn relay just like in the old days. I like that I am not totally against the electronic wizardry of our cars but their are some cases of it going too far. Like door latches and shift lever operation. It would suit me fine if these things didn't need a computer to operate.
Just my experience and thoughts.
ButWhatDoIKnow (04-25-2021)
Received 2,052 Likes
St. Jude Donor '13
1. Use your key to open the trunk. Have earplugs in case alarm goes off.
2. Pull manual release tab for driver's door (located in trunk).
3. Open driver's door, pull hood release.
4. Open hood, connect battery charger or jumper cables.
If you can't get the hood open, you can connect a charger to the starter cable under the car. If you jack up the car for access, be sure to place jackstands or extra wheels so you won't be crushed if the jack goes down.
Do yourself a favour and order this:
http://www.amazon.com/Jump-N-Carry-JNC300XL-Ultraportable-Starter-Light/dp/B000XQ9MGE/ref=wl_it_dp_o?ie=UTF8&coliid=I2MAWOAW04 CFZ8&colid=LQXXI5MB679N
Jump-N-Carry JNC300XL 900 Peak Amp Ultraportable 12V Jump Starter with Light
$59 bucks. Free 2 day shipping with Amazon prime. $3.99 Overnight shipping with Amazon Prime. It will be at your house tomorrow! Its even small enough to keep in the car, and holds enough energy to jump a car several times without recharging. Many reviews about it say it holds a charge for up to 6 months and is still strong enough to crank the engine.
St. Jude Donor '13
I'm assuming that he has room to at least connect a charger to the battery. If there is no electrical outlet there, then run an extension cord or use jumper cables (I keep a set of long ones). If he's in a hurry, connect the charger/jumper just long enough to put the car in Neutral.
Another trick is to jack up the rear of the car and set it on a dolly or creeper, so it can be moved while the rear wheels are locked.
To the OP, if the battery is dead....use the trickle charger that plugs into the lighter socket. At full bore, it takes about 15 minutes to get enough juice to start it. On low trickle, overnight will fully charge a battery....Its the easiest solution if its not your DD.
You should post in the C7 section, as this is the C6 forum. A little more info would also be helpful
Received 1,792 Likes
can you turn on the accessory mod? under accessory mod, by pressing the brake, you can shift to neutral.
