I've got a 2007 Z-51 with the tinted top. The top creaks and pops whenever I drive the car. Especially the front left corner. Does anyone else have this problem? If so, have you found a fix? Thanks
Here , at last there is someone the same problem !
This is the 6 th time that mechanics test corrected the problem and they are not capable.
I do not know what to do, because it's really noisy !
Michel
Thanks to everyone for the quick.......and witty replies. I went to the recommended site on the forum and read about the E clip remedy. It seems to be very successful and I plan to try it very soon. I will let you guys know the results. Thanks again - - - great forum!
I had this problem on my 08. Take yours to the dealer and get the up to date mounting brackets for the top.
I have a 2007 Z-51 Coupe with a clear top.
I bought the car used from a Chevy dealer, so I had a warranty. I took the car to the dealer and they did the new mounting brackets. The top was still noisy.
I read the TSP carefully and the trick for me was to clean the rubber thoroughly with soap and water. Actually Windex did the job. Then apply Super Lube to all the rubber and rub it in good with your fingers, also put some on the metal pins front and rear.
I had tried Super Lube before and it didn't work because I didn't clean all the rubber thoroughly.(that is the trick). I have been riding around for about a month and the top is dead quiet.
seems to go away in mine when the weather cool downs or if I don't remove the top for a while - never tried to waste my time by getting the dealer to try fixing it
