Navigation Question
Old Aug 11, 2011 | 10:58 AM
IDSRVIT's Avatar
IDSRVIT
Default Navigation Question
Need some help from the CF.
I read / followed all the navigation set-up instructions and I put in a local address in Sioux Falls, SD with correct start & end address, city, zip, etc and I go to start the trip and once done calculating the navigation system is telling me my starting location is in Tennessee and my trip which should be a 15-20 minute trip is being quoted as 26hr, 37 minutes trip in the navigation.
My first thought is I had the wrong region selected, so I checked that but nope it's in the correct region.
Any ideas?
My wife who is as close to a navigation expert (can jump into any make of vehicle and have no issues with any navigation system) can't figure it out either.
Any help would be appreciated.
Old Aug 11, 2011 | 11:01 AM
RicK T's Avatar
RicK T
Can't help with your question but.....if you haven't read Talon90's Nav tutorial you might want to do that at some point. It has helped many here.
http://forums.corvetteforum.com/c6-c...rough-5-a.html
Old Aug 11, 2011 | 11:10 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
It sure sounds like the wrong region. Do you have the correct disc in the Nav unit? Do you require the western disc?
I'm guessing here...
Old Aug 11, 2011 | 11:26 AM
Duke/Earl's Avatar
Duke/Earl
I have two cars with GM nav. You do not need to imput a starting address, it knows where you are. Check that you have it set on the correct region.
Old Aug 11, 2011 | 11:52 AM
rchbn's Avatar
rchbn
You have to clear your saved way points, I had the same problem after moving from Chicago to AZ every trip I started first calculated from Chicago to 18 miles away but it would work correctly but the calculation took a lot longer. I don't remember the steps but I cleared everything made sure I was in the correct region and it worked better after that but mainly I use my Garmin now as it's so much easier to use.
Old Aug 11, 2011 | 12:02 PM
IDSRVIT's Avatar
IDSRVIT
Correct DVD yes......
IDSRVIT's Avatar
IDSRVIT
I'll look at this tonight... Thanks
Old Aug 11, 2011 | 12:03 PM
IDSRVIT's Avatar
IDSRVIT
Thanks Rick
Old Aug 11, 2011 | 12:15 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
You've all ready been linked to my tutorial and all of this will be in there but make sure you have "allow major roads" selected in your user preferences. Make sure that you are in the correct region. Keeping in mind that you must be in the destination region to enter the address and select it for guidance. Make sure that you view the "3 routes" button, that will give you the option to change your route selections (shortest, quickest and normal) and see if any of them are closer to your expectations for the route.
If this car was previously owned, make sure that there are no prior destinations or waypoints showing as still programmed. The car could be trying to take you to your selected destination via a waypoint that the previous owners left in there.
If you have any questions on this or the tutorial, please feel free to PM me or email me.
Paul
Old Aug 11, 2011 | 12:20 PM
Atomic Punk's Avatar
Atomic Punk
Originally Posted by talon90
You've all ready been linked to my tutorial and all of this will be in there but make sure you have allow major roads selected in your user preferences. Make sure you are in the correct region. Keeping in mind that you must be in the destination region to enter the address and select it for guidance. Make sure that view the "3 routes" button that will give you the option to change your route selections (shortest, quickest and normal) and see if any of them are closer to your expectations for the route.
If this car is was previously owned, make sure that there are no prior destinations or waypoints showing as still programmed. The car could be trying to take you to your selected destination via a waypoint that the previous owners left in there.
Paul
you are the man paul!...
Old Aug 11, 2011 | 12:21 PM
Jakeross's Avatar
Jakeross
Make sure your region is set right. Is the address a private road? I input an address in TX that is a private road and the Nav tried to send me to OK. City.
Old Aug 11, 2011 | 01:52 PM
IDSRVIT's Avatar
IDSRVIT
Paul
Thanks Paul
Old Aug 11, 2011 | 02:38 PM
Cypher's Avatar
Cypher
There is no “start” address required. You just need to plug in your required destination.
I have 3 GM vehicles w/Nav and they all work differently, but none require a “start” address.
To Navigation Question
