brake pads
Old Aug 15, 2011 | 11:40 PM
cs1841's Avatar
cs1841
Default brake pads
Hey guys, tired of cleaning the rims everytime I take out my 2010 GS! I have tried a couple of the dust repel products with moderate success. Just wondering what is the best pad out there with the least amount dust. I know hawks are good, but which one is best for street use? Any help would be great!
Old Aug 16, 2011 | 12:07 AM
BearZ06's Avatar
BearZ06
St. Jude Donor '09 thru '17,'22 thru '26
I went with Semi Metallic pads years ago, 90% less duct and no squealing like ceramics sometimes do.
http://forums.corvetteforum.com/c6-z...m-is-back.html
Old Aug 16, 2011 | 12:17 AM
TMyers's Avatar
TMyers
Originally Posted by BearZ06
I went with Semi Metallic pads years ago, 90% less duct and no squeal like ceramics.
No squeal out of my ceramics.
Old Aug 16, 2011 | 12:22 AM
SilverScorp's Avatar
SilverScorp
The best your going to do is ceramic pads, but they will fade when they get hot if you track your car. Semi-metallics have a bit more dust but not as much as the stock pads.
Old Aug 16, 2011 | 12:26 AM
TMyers's Avatar
TMyers
Originally Posted by SilverScorp
The best your going to do is ceramic pads, but they will fade when they get hot if you track your car..
Easy, I have 2 sets of pads, ceramics for daily driving and track pads for HPDE's. Ceramics work fine when autocrossing but would never stand the heat of a HPDE. Front brakes reach 1100 deg depending on track.
Old Aug 16, 2011 | 09:44 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Take a look at the Carbotech 1521 compound, you can do a search on the forum for feed back, I can tell you that we have sold thousands of this pad and it performs as advertised.
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser, and has won multiple SCCA Solo 2 and Prosolo National Championships. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. Bobcat 1521™ compound has also been found to extend the life of your rotors 2-3 times. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
F $282 R $239 Less 7% forum discount.
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
To brake pads
