Dead Battery
Old Aug 17, 2011 | 08:36 AM
jamie furman's Avatar
jamie furman
Default Dead Battery
My 2005 corvette battery just went dead and when I put in a new battery the car went in to limp mode and says reduced power with check engine light. When I scanned the code it says learning problem with tps, has anyone had this problem? And if so can anyone help me with a solution. Thanks in advance.
Old Aug 17, 2011 | 09:01 AM
Top_Fuel's Avatar
Top_Fuel
Look at the voltage on your DIC. What voltage does it read with/without the engine running?
These cars do crazy things without adequate battery voltage. You don't want to assume that just because you have a new battery that it is actually charged and in good shape.
Old Aug 17, 2011 | 12:58 PM
ssv3's Avatar
ssv3
I was thinking the same exact thing. When my battery went bad I bought a brand new battery and it was bad. Changed it out and everything back to normal again. Good Luck!
Old Aug 17, 2011 | 02:20 PM
carpe dm's Avatar
carpe dm
Been there........
Old Aug 18, 2011 | 07:29 AM
jamie furman
I bought the battery at the chevy dealer and they check them before they leave and I thought the same thing as you guys so I put the trickle charger on it and withing 30 minutes it was at its top level.
There is a procedure you have to do once this happens which does happen frequently I was told, I just didn't want to have to go to the dealer if someone had already done the procedure and could explain it to me.
Old Aug 18, 2011 | 07:44 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I've replaced the battery on my '07 and there was no complications in doing so such as any procedure other than re-indexing the windows.
To Dead Battery
