Who uses additives?
Old Aug 18, 2011 | 05:46 PM
LDB's Avatar
LDB
The incidents a few years ago where fuel gauge sending units were wiped out had nothing to do with additives. About that time, environmental rules caused sulfur content in gasoline to be reduced from prior levels around 1000ppm to 30ppm. Refiners had to add desulfurization units to do that. Mostly, that’s good for cars, the air, catalytic converters, etc. However, there is a particular operating regime the desulfurization units can get into, where most of the sulfur is removed like it is supposed to be, but what little sulfur is left, can be a particularly aggressive type. It’s a very complex chemistry beyond the scope of this type of forum to discuss, and it was not well understood prior to initial operation of these units. Once refiners figured out what was going on, they took steps to stay away from that operating regime, and have been very successful in doing so after the initial flurry of problems occurred. It wasn’t anybody’s “fault”. It was simply that sometimes, you think you are doing the right thing, but subtle things you don’t fully recognize come up to bite you. Back to the topic of additives, it was the aggressive sulfur species that ate up the fuel gauge senders, and there’s not an additive on the planet that can prevent fuel gauge problems if a refinery is operating in the regime leading to the aggressive sulfur. The only thing that can prevent the fuel gauge problem is to keep the refinery desulfurization units out of that operating regime, as they have been doing very well since the initial year or so of learning curve experience. So the bottom line of the story is, assuming you use top tier gas, you are wasting your money on additives.
Old Aug 18, 2011 | 05:48 PM
Sunset-C6's Avatar
Sunset-C6
All additives are a waste of money...
Old Aug 18, 2011 | 10:26 PM
RonsGS's Avatar
RonsGS
St. Jude Donor '12-'13
Originally Posted by Xedes
Keeping in mind the average age of this forum, I would think the most popular additive would be Viagra.
I was just going to say that.....
Old Aug 18, 2011 | 11:05 PM
TSLAVette's Avatar
TSLAVette
Originally Posted by talon90
Additives are generally not needed or recommended. The only thing I will add (other than using top tier gasolines) is to add a bottle of Techron fuel system cleaner with a fill up once per year to keep the fuel sending units healthy.
I agree with Talon ... the only other additive used by many on this forum (of advanced age) ... is the "little blue pill"
Old Aug 18, 2011 | 11:06 PM
TSLAVette's Avatar
TSLAVette
Damn, I just did! Looks like Ron is on the Racer avatar program too!!!
Gering's Avatar
Gering
Tolero Apto Victum
I like to use this now and then.
Old Aug 18, 2011 | 11:22 PM
SilvrVette's Avatar
SilvrVette
BG 44K maybe twice a year and only when I know I'll burn the whole tank in one trip
Old Aug 18, 2011 | 11:34 PM
Rocketmanwpb's Avatar
Rocketmanwpb
I try to use Chevron gas as often as possible and once a year put in a bottle of Techron
Old Aug 18, 2011 | 11:53 PM
LMB-C6's Avatar
LMB-C6
I use a bottle of Techron once a year - mostly because it makes me feel good...the car could probably care less.
Old Aug 18, 2011 | 11:58 PM
AJRace's Avatar
AJRace
Lucas Injector cleaner, great stuff...I put it in all of our cars.
Old Aug 19, 2011 | 12:12 AM
1Corvette's Avatar
1Corvette
Guys, stop and think about it for a minute. Do you really believe that you can add a $5.00 can of snake oil from Walmart and improve the formula that the oil company spent millions developing? The answer is NO. Additives, both fuel and oil only do one thing. They make the company selling it a lot of money, your hard earned money. Keep it in your pocket to buy parts to make your Corvette faster. Don't waste it on additives that don't do squat. End of story.
Old Aug 19, 2011 | 05:14 AM
Swiftrider08's Avatar
Swiftrider08
Dis-agree. No matter how good the gas is your using, carbon deposits will build up on the injector tips, back side of valves, intake ports, piston tops and rings and just about everywhere thru the engine over time. Nothing to argue about, just simple fact. When combustion takes place, some byproducts are left behind. Techron has been proven many times to be the best out there for breaking this stuff up and letting it pass on thru the engine. Also good for keeping sending units happy. A bottle or two a year is a good thing for any gasoline powered vehicle.
Old Aug 19, 2011 | 05:41 AM
  #33
Ketchum's Avatar
Ketchum
Marvel Mystery oil to the fuel every now and then.
Old Aug 19, 2011 | 09:23 AM
  #34
GSRANDY's Avatar
GSRANDY
AMSOIL PI - Performance Improver, every 4,000 miles.
http://www.amsoil.com/storefront/api.aspx
Regards,
GSRANDY
Old Aug 19, 2011 | 09:27 AM
  #35
NYC6's Avatar
NYC6
Old Aug 19, 2011 | 09:28 AM
  #36
User 81424's Avatar
User 81424
Additives are generally not needed or recommended. The only thing I will add (other than using top tier gasolines) .
I just use Stabil for storage.
Old Aug 19, 2011 | 02:46 PM
  #37
AH2005C6's Avatar
AH2005C6
Thanks for the great info on additives. What about octane boosters?
To Who uses additives?
Old Aug 20, 2011 | 12:56 AM
  #38
1Corvette's Avatar
1Corvette
I don't choose to argue either, but do you have any scientific proof? I will recant my statement and admit I was wrong if I see an independent study or research to prove a product is more than marketing hype.
Old Aug 20, 2011 | 06:23 AM
  #39
Swiftrider08
Not the kind of "proof" I am sure you are looking for, but take a minute and read the following article:
http://www.carsandparts.com/Articles...ine-deposits-1
This was in the latest edition of AutoEnthusiast magazine, which is a great magazine for car guys/gays.
Lastly, just type Techron into Google and you will find all the reviews you have time to read. Always positive comments.
Old Aug 20, 2011 | 11:03 AM
  #40
Ketchum's Avatar
Ketchum
Years ago when I was involved with Nissan's there was lots of severe hesitation from off idle. Nissan started endorsing Techron. BMW also pushed and endorsed Techron. I probably use Chevron 80% of the time. I use some Shell. I use once in a while no name discount gas but usually avoid it. I like using MMO as a fuel system cleaner in my gas engines and my diesels.
