Lifter noise normal?
Old Aug 25, 2011 | 06:34 PM
incabird's Avatar
incabird
Default Lifter noise normal?
I have a 2011 base coupe and notice some lifter noise. Is this normal for the LS3 engine? I notice it from inside the car. I only have a little over 900 miles on the car. I have not had the motor over 5000 RPM and have followed the recommended break-in procedure.
Old Aug 25, 2011 | 06:35 PM
Larry/car's Avatar
Larry/car
Normal
Old Aug 25, 2011 | 06:38 PM
Gman in NC's Avatar
Gman in NC
Yea, I think it's normal too. Mine's been doing that for six years.
Old Aug 25, 2011 | 06:39 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Sure your not hearing fuel injector noise?
Old Aug 25, 2011 | 07:34 PM
Dif's Avatar
Dif
It could be the Injectors.
I never noticed it until one day on a newly paved highway and no tire noise.
Car was so quiet all I could hear were the Injectors.
Old Aug 25, 2011 | 09:20 PM
fnsblum's Avatar
fnsblum
No!
Old Aug 25, 2011 | 10:35 PM
NYC6's Avatar
NYC6
If you do headers you'll hear all that lovely mechanical music even more. The long tubes act somewhat like a tuning fork in transmitting the moving parts working. Sounds great to me.
Old Aug 26, 2011 | 08:53 AM
etaylor14's Avatar
etaylor14
There should be NO lifter noise. That is why hydraulic lifters were invented!!
Old Aug 26, 2011 | 10:03 AM
simplegto's Avatar
simplegto
St. Jude Donor '11-'12-'13-'14
All LS motors are noisy due to the fact aluminum blocks don't absorb the sound like iron blocks do.
Old Aug 26, 2011 | 10:13 AM
Turbo6TA's Avatar
Turbo6TA
And if you install a wide-profile aftermarket cam with lots of lift, you will get lots of valvetrain noise do to the fact that the 'ramp speeds' are so fast ... at least in the aluminum block LSx engines.
Old Aug 26, 2011 | 10:46 AM
P0234's Avatar
P0234
All pushrod motors make those sorts of noises. You can hear them very well if you drive next to a concrete divider/wall. As long as the noise is uniform, ie one lifter doesn't stand out, its fine. The people that say they can't hear anything are just deaf.
Old Aug 26, 2011 | 10:52 AM
lastcowboy's Avatar
lastcowboy
first thing i noticed on my new GS no''noise .my o9 and 08 are loud as h***.you should here no lifter noise if that motor is tight.i have went round and round with GM but all i hear is "THATS NORMAL" same when the tops were flying off THATS NORMAL'' selling the 09 and 08 before i have real probs.ck. you vin in the gm bul.see if they have had other comp.you will hear some inj. noise with the hood up.
.IF THIS WAS NORMAL every car would sound that way . go back to the dealer start some other cars up see what you think.best of luck
Old Aug 27, 2011 | 03:21 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Have you spoken to your dealership yet? I would suggest riding along with them so you can make sure they’re aware of the exact noise you’re hearing.
Thanks,
Laura
GM Customer Service
Old Jan 12, 2012 | 10:58 AM
MR_JLR's Avatar
MR_JLR
Is this the noise that is considered normal? Just trying to get an idea
LS2 GTO
Old Jan 12, 2012 | 11:03 AM
Vivid1's Avatar
Vivid1
injector pulse is noisey. Also, hydrolic lifters will still tick.
Old Jan 12, 2012 | 11:22 AM
C7Joy's Avatar
C7Joy
The only time I am conscious of my lifters making noise is rarely upon startup, and then the noise goes away quickly as the oil pressurizes. Not hearing anything while driving.
To Lifter noise normal?
