wheel lock lugs
Old Aug 30, 2011 | 10:22 PM
TSLAVette's Avatar
TSLAVette
Default wheel lock lugs
what do you fellas use that won't mess up balance & are decent quality?
Old Aug 30, 2011 | 10:27 PM
Shawn S's Avatar
Shawn S
Twenty individual locks…..perfect balance
Old Aug 30, 2011 | 10:32 PM
Walt White Coupe's Avatar
Walt White Coupe
And quality chrome.
jeffjob's Avatar
jeffjob
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
St. Jude Donor '13, '17-'18, '25
as well
Old Aug 30, 2011 | 10:35 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
GM/McGard
Not as effective as the Gorillas, but free from my dealer.
Old Aug 30, 2011 | 10:39 PM
Walt White Coupe
You really are a cheapskate.
Old Aug 30, 2011 | 11:18 PM
Rocketmanwpb's Avatar
Rocketmanwpb
Originally Posted by Gearhead Jim
GM/McGard
I purchased the GM wheel locks for my C5 and transfered them to my C6.
Old Aug 30, 2011 | 11:21 PM
keyplyr's Avatar
keyplyr
I use 20 of these:
Old Aug 31, 2011 | 12:31 AM
C5-JIM's Avatar
C5-JIM
Weigh the lug nut and then weigh the locking nut. Subtract the difference and get a nut and bolt that is the same weight as the difference. Bolt that to the location where you are planning to put the locking lug. Spin balance the tire and rim. Remove the nut and bolt and replace it with the locking nut. You will have a balanced system. repeat on other 3 mounted rims.
C5-JIM
Old Aug 31, 2011 | 12:46 AM
Crow Hunter's Avatar
Crow Hunter
McGards work fine on my '97 and my '06. Absolutely no problems.
Old Aug 31, 2011 | 06:50 AM
VET4LES's Avatar
VET4LES
Old Sep 1, 2011 | 02:09 PM
TSLAVette's Avatar
TSLAVette
Thanks, fellas! Gorilla it is. I see a 12mm and 14mm ... I presume 12mm is the right size? Also looks like you're using all 5 on each wheel ... why not just one or two? Looks effective.
Old Sep 1, 2011 | 03:07 PM
vettdreamer's Avatar
vettdreamer
I stongly recommend on all 5 and make one of them the gorilla type that has the spinning sleeve or maybe all with the sleeve
http://www.gorilla-auto.com/gorilla.guard.locks
trust me I had one locking nut on my vette left it out one night and this happened it makes me sick everytime i see walk by it and im still waiting on insurance I cant move nothing. I think I may even hook up 10.000 volts to the wheels try to get then then ha ha
http://forums.corvetteforum.com/c6-c...just-look.html
Old Sep 1, 2011 | 05:18 PM
dvilin's Avatar
dvilin
Same here.
GM/McGard
Old Sep 1, 2011 | 05:40 PM
b4i4getit's Avatar
b4i4getit
I am only counting 16 in that package.
Old Sep 1, 2011 | 08:59 PM
WAwatchnut's Avatar
WAwatchnut
The rest are under the label.
To wheel lock lugs
