C6 low beam problem
Old Sep 1, 2011 | 11:33 AM
Hjjvet05's Avatar
Hjjvet05
2nd Gear
Default C6 low beam problem
Only have high beam lights Sometime ????
Old Sep 1, 2011 | 12:59 PM
RaleighTL's Avatar
RaleighTL
Do a search on this forum and you will find a great deal of info;
as I recall the most common cause was a faulty fuse box. Yep I said the fuse box. Again it's just my recollection, I think there is circuitry built in the box that is faulty (breaks).... go check it out, and you should be able to fix it yourself should you choose ....
Old Sep 1, 2011 | 01:25 PM
RaleighTL's Avatar
RaleighTL
PM sent .. check out =>
http://forums.corvetteforum.com/c6-c...headlamps.html
To C6 low beam problem
