Sputtering when accelerating
Old Sep 4, 2011 | 03:04 PM
JROCK747's Avatar
JROCK747
Default Sputtering when accelerating
Good afternoon all. Just looking for any info reference a sputtering I just noticed while shifting thru the gears. The car is up to date on all required maintenance and just crossed over 85k. I was in third accelerating and noticed the engine hesitating. I pushed it harder and it got worse. I tried this in second and fourth gear only to notice the same thing. Now please note I had just filled up the tank and was driving home from the gas station. Have never noticed this before and was just curious what this might be. Any info would be greatly appreciated. Have a great holiday weekend to all.
Old Sep 4, 2011 | 03:08 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Most probably some water in the gas you had just filled up with. Try dumping a can of dry gas in to your tank.
Old Sep 4, 2011 | 03:30 PM
Don-Vette's Avatar
Don-Vette
Get the injectors cleaned and carbon deposits on the underside of the valves.
Old Sep 4, 2011 | 04:54 PM
carpe dm's Avatar
carpe dm
A bottle of Techron, a few miles, and a few "quick passes" should help out.
Old Sep 4, 2011 | 05:57 PM
1FASTVERT's Avatar
1FASTVERT
St. Jude Donor '12
Maybe even 2 bottles of Techron.
Old Sep 4, 2011 | 09:28 PM
laconiajack's Avatar
laconiajack
Gas cap on tight?
Old Sep 4, 2011 | 10:22 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Originally Posted by laconiajack
Gas cap on tight?
My thoughts exactly !
Old Sep 4, 2011 | 11:49 PM
CandyRed77's Avatar
CandyRed77
Check your airfilter and throttle body, and make sure they are clean.
Sonny
Old Sep 5, 2011 | 12:02 AM
Rogers 07's Avatar
Rogers 07
If it was running fine before the last tank of gas, then its most likely water or something in the fuel. As others have said try some Fuel drying additives These are about 90% pure alcohol and wont hurt anything. !!
Old Sep 5, 2011 | 03:39 AM
keyplyr's Avatar
keyplyr
Probably runflat related
Old Sep 5, 2011 | 07:09 AM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
To Sputtering when accelerating
