Help!!
Old Sep 5, 2011 | 03:16 PM
Tom Jacobs's Avatar
Tom Jacobs
Cruising
Default Help!!
Just bought a 2005 C6 coupe - a fifty year dream come true.
It's been running fine until yesterday when the push-button start just clicked once and that's it. No problems with the car for six months - only 33K miles. Any suggestions appreciated.
Thanks, -Tom.
Old Sep 5, 2011 | 03:17 PM
EVRose's Avatar
EVRose
Your battery is dead.
Old Sep 5, 2011 | 03:20 PM
Larry/car's Avatar
Larry/car
I agree, check the voltage on the DIC, you probably will see something below 12 volts.
Raazor's Avatar
Raazor
Goon Squad King of Battle
St. Jude 15 Year Donor
St. Jude Donor '08 thru '23
yup
Tom Jacobs's Avatar
Tom Jacobs
Cruising
Even though lights, radio, etc. run when I hit Accessory On?
Thanks for your quick response.
Old Sep 5, 2011 | 03:22 PM
Vette_DD's Avatar
Vette_DD
Yes, those things require very little voltage compared to what it takes to start the car.
And remember that after you replace the car battery, you'll need to reset the clock and reset the window indexing.
Close the car door. Raise the window and hold the up switch an extra 3 seconds. Release. Without lowering the window, hold the up switch again for 3 seconds. Release. Done. Don't forget the other window.
Old Sep 5, 2011 | 03:23 PM
Tom Jacobs's Avatar
Tom Jacobs
Cruising
Thx, I'll do that. My first 'Vette and still learning everyday - I'm obviously not a mechanic.
wayback's Avatar
wayback
Yep, check volts then hit start button and check volts again.
Time for a new battery.
Old Sep 5, 2011 | 03:24 PM
Vette_DD's Avatar
Vette_DD
Lots of things to learn about the C6 and those of us that have lots of experience enjoy helping others.
Old Sep 5, 2011 | 03:26 PM
Raazor's Avatar
Raazor
i'm shocked your battery lasted as long as it did.
if it's a toy and parked over two weeks without driving, you need to purchase a battery tender also. trust me, if it's not a daily driver, just go to Batteries Plus and get one now.
Old Sep 5, 2011 | 03:34 PM
Tom Jacobs's Avatar
Tom Jacobs
Cruising
Thx. I'll do that. Have a Batteries Plus within a mile.
Old Sep 5, 2011 | 03:43 PM
Fly'n Family's Avatar
Fly'n Family
Sound advice and a cheap investment that will save you all kinds of headaches.
Old Sep 5, 2011 | 03:48 PM
LMB-Z's Avatar
LMB-Z
Check your battery connections first, make sure they are not corroded. If they are making good connections, I agree with everyone else.
Old Sep 5, 2011 | 03:54 PM
David c6's Avatar
David c6
Also don't forget to put the shifter in reverse when parking if it's a stick shift..
Old Sep 5, 2011 | 03:59 PM
Black05's Avatar
Black05
Not a day goes by that I don't learn something on this forum.
One of the biggest lessons is,that if you have an electrical issue,it's probably the battery. Owning an 05, I purchased a CTEK 3300.
Car starts right up every time. Thanks guys.
Old Sep 5, 2011 | 09:18 PM
RT2SJB's Avatar
RT2SJB
Default Test
Turn your headlights on and hit the start switch. If the lights dim its the battery if the lights stay bright you have another problem.
Old Sep 5, 2011 | 09:45 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
'05 only ............
To Help!!
Old Sep 5, 2011 | 09:49 PM
User 81424's Avatar
User 81424
Old Sep 5, 2011 | 09:56 PM
WMark's Avatar
WMark
St. Jude Donor '11
My 2010 battery didn't last a year.
Cheap insurance.
By the way, welcome!
Old Sep 5, 2011 | 10:00 PM
Raazor's Avatar
Raazor
