Squeaky Suspension!!
Old Sep 6, 2011 | 11:28 PM
Jerky's Avatar
Jerky
Default Squeaky Suspension!!
I have a 2008, non-Z51 C6. I noticed today that the suspension squeaks big time when I go over speed bumps. I don't recall seeing any zerks anywhere, so how the heck do I get rid of the squeaks?!?!
Old Sep 6, 2011 | 11:38 PM
widgetsupply's Avatar
widgetsupply
Loose end link?
Old Sep 7, 2011 | 12:08 AM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Feed the mice ................
Old Sep 7, 2011 | 09:31 AM
Jerky's Avatar
Jerky
feed the mouse this morning,. I'll check the links tonight...anything else that could cause it?
Old Sep 7, 2011 | 11:57 AM
Sunnyvale Dave's Avatar
Sunnyvale Dave
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'19
When I had this problem on my '06, it was the rear sway bar end links.
Old Sep 7, 2011 | 12:18 PM
PatriotZ's Avatar
PatriotZ
From: "No matter where you go... there you are"...."You cannot drive a dollar bill". ...and remember... "D
Same here....also make sure your axel nuts are tight,
Old Sep 7, 2011 | 12:19 PM
VETFEVER's Avatar
VETFEVER
Have you installed aftermarket lowering bolts??
vetfever
Old Sep 7, 2011 | 08:00 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
vetfever
I was gonna ask the same or, has the car been lowered somply by turning the stock height adjustment bolts ..............
Old Sep 7, 2011 | 09:07 PM
thehueg's Avatar
thehueg
It's the "H" hanger springs that hold the two exhaust pipes about half-way down the middle of the car. Most dealers are aware of this and repair no charge. There is a fantastic video showing this on this site.
Old Sep 8, 2011 | 12:09 AM
RockIT9's Avatar
RockIT9
squeaky aftermarket lowering bolts, worst mod ever
Old Sep 8, 2011 | 05:05 AM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Wonder when folks are gonna learn ..............
Old Sep 8, 2011 | 10:28 AM
Jerky's Avatar
Jerky
Nope. Not here The car is low enough already. I didn't get a chance to check last night, but I decided to drive her to work today, and I'm hearing it on both the front AND the back when I go over the speed bumps in my neighborhood. It's sounding like it very well might be the end links, but I'll check the H-pipe too.
Old Sep 8, 2011 | 01:26 PM
carpe dm's Avatar
carpe dm
It turned out that our "squeak" was our sway bar bushings. A little silicone grease took care of it. Only had it in the front, though.
Old Jun 20, 2024 | 10:30 PM
Blanice's Avatar
Blanice
8th Gear
can you describe the squeak in any other way or when exactly was it happening? I feel like I am having the same exact issue and the squeaks are getting so loud when I do 15 and under.
Old Jun 21, 2024 | 05:14 AM
StayinStock's Avatar
StayinStock
2023 C6 of the Year Winner - Modified
Considering this thread is from 2011 and Carpe hasn't been active since 2017 I'd wager you wont get a response. Its ok to start a new thread lol
To Squeaky Suspension!!
