Outside mirrors turn down with engine off cycle
Old Sep 7, 2011 | 05:52 PM
check6x's Avatar
check6x
Default Outside mirrors turn down with engine off cycle
I read a bunch of dead battery threads and didn't see this problem. The window indexing problem cleared after a couple of openings and closing. The outside mirrors keep adjusting to full down, the car was idle for about 8 weeks and the battery was dead. Any ideas, insights or should I read the owners manual?
Old Sep 7, 2011 | 05:56 PM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
I think you can turn that option off in options through the DIC. I would imagine that the instructions for it on in the manual also.
Old Sep 7, 2011 | 06:11 PM
lastcowboy's Avatar
lastcowboy
they set for driver *1 or -2 .set everything for driver 1 push button for 1 till it beeps ,turn the motor off then start it and the m. should reajust for dr.1 .good luck
Old Sep 7, 2011 | 06:23 PM
Vette_DD's Avatar
Vette_DD
No, there's not a way to turn that off. All you can do is set them for fob 1 or fob 2 by using the door button.
To Outside mirrors turn down with engine off cycle
