I got four new wheels for my '09Z and bought four TPMS sensors from the Chevy dealer. The car shows that the sensors are there, but they all read about 4 psi low. The sensors in the previous set of wheels were right on.
Do these things need to be calibrated? Does the dealer have to do this, or can I buy a tool to do so?
If you didn't retrain, the car is either remembering the old pressures from when your original wheels were installed, or it's picking up the signals from the old wheels/sensors if they are sitting in your garage.
The Dealer or aftermarket CANNOT calibrate the sensors, all they can do is register their location on your car.
I also think Gearhead Jim has a valid point about the car picking up the info from the old tire/wheels. Try moving the old wheels at least 50 feet away from the car.
You may need to drive 20-25 miles at one stretch away from the house to get the old sensor info to delete itself. The sensors go into a semi sleep mode if you stop for more than 15 minutes, so you have to keep moving for quite a while.
Well, now the car isn't receiving the sensors. This probably is good news. The readings that I thought were erroneous may have been holdovers from the previous sensors, and now that the TPMS has "woken up" and looked around, it can't recognize any sensors.
If you were close to where I live, I'd Volunteer to reprogram them for free with my programmer.
BTW, old wheels/sensors are miles away.
Now that you're away from the old sensors is the time to reprogram to identify the new sensors. When you get back to the area where the old sensors are located, make sure you store them 50+ feet away from where you'll ever have the car. You could wrap the old tires in aluminum foil if you need to store them closer.
I'm thinking that if the car is trained for the new sensors, it doesn't matter where the old ones are stored. Kinda like if another Corvette parks beside you, the cars ignore each others sensors.
We have two sets of wheels/sensors/tires (winter and summer). The set that is not in use is stored about 10 feet away from the car in my garage, no issues.
I was thinking of a different issue where sensors are cloned. The OP now has a set of sensors with totally different IDs. My bad.
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Originally Posted by cclive
They need to be programmed. And there is no calibration...what the new ones will send is it...no adjusting.
There is no calibration. The come calibrated from the factory. Telling the car to look for a different TPMS sensor set is a different matter. You just have a Chevy dealer who doesn't have a clue how tire sensors work and that the car needs to be told the new IDs when you change them. That's why you go to a tire place who does things like this all the time rather than a dealer who may change a TPMS sensor once a year.
