The climate control display on my 2008 C6 Z51 is acting up. The display blinks rapidly. The system seems to work just fine and it will reset when the engine is restarted. The display will be fine for a time and then will do the blinking again. Anyone have any idea what might be causing this?
If you can find somebody with a scanner that can read the HVAC codes you might find there is an issue with the system. I know the chain auto parts stores don't have any capable of reading those codes so don't bother with them.
From: I warm so easy so dance me loose -- it shines so bright the moon
Originally Posted by nickTsandman
Had the same problem on my 07, the fix was replacing the AC Control Head (display unit). It was covered by my warranty.
Was that the 3yr/36month warranty or the 5/100? Ask becauseI have fhe same problem with my '07. (and the 3/36 warranty has expired but the 5/100 is still in play.)
The 5Yr/100K warranty is power-train only. It will not cover the hvac
stoessjc – it’s been a few days since you posted so I was curious if you made any progress with your climate control system. If you’re still having issues with it, be sure to send me a PM.
My did the same today, pulled the 10 amp a/c fuse and reinserted again, and blinking went away, the unit never did stop working while blinking display was there.
