Wide Body Conversion Question
Old Sep 22, 2011 | 11:44 AM
Eppieguy's Avatar
Eppieguy
Default Wide Body Conversion Question
I'm ordering the parts for my wide body conversion, just for the rear for now and I have found 2 parts list and there is one difference between parts. Can anybody help me as to what the difference in parts is?
Rear Brake Scoops Outer
Left 15787683
Right 1584237
Then there is
25790357
29790358
listed as the same. Ideas?
Old Sep 22, 2011 | 11:49 AM
Xedes's Avatar
Xedes
The outer is probably the small black piece the snaps in from the outside of the fender. The other part will probably be the inner air duct to direct the air to the brakes. Only a guess.
Old Sep 22, 2011 | 12:07 PM
ncvette_1FUNRIDE's Avatar
ncvette_1FUNRIDE
2015 C6 of the Year Finalist
Left 15787683
Right 1584237
Then there is
25790357
29790358
These are the part numbers for the brake scoops outer pieces.
Not sure what the top numbers are for.
Old Sep 22, 2011 | 12:42 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Left 15787683
Right 1584237
Then there is
25790357
29790358
The bottom two parts are the current correct part numbers. These two items replaced 15787683 (L) and 15787684 (R) which was the original part number (at the second number you list is not a valid part number.
The original part numbers for the inner scoop are
15842370 (L) and 15842371 (R) which is what I think you were trying to type for your second item at the top of your original list.
Old Sep 22, 2011 | 01:52 PM
Eppieguy's Avatar
Eppieguy
Thats what I was looking for, Thanks! Looks like the rear fenders got new numbers too.
20972892
20972090
To Wide Body Conversion Question
