When I open the passenger door the window lowers to allow the door to open, but when I close it the window does not go back up into the closed position, so I have to use the switch to raise the window. Is this an issue for the dealer?
Thanks for all your advise, everything is working now!
Try this on that window. Start with the window all the way down.
Close the car door. Raise the window and hold the up switch an extra 3 seconds. Release. Without lowering the window, hold the up switch again for 3 seconds. Release. Done. Don't forget the other window.
This is called resetting of the window indexing or power window initialize and is in the owner's manual. See page 2-17 of the 2005 owner’s manual, page 2-18 of the 2006 owner’s manual, page 87 of the 2007 owner’s manual, page 2-18 of the 2008 owner’s manual, page 2-18 of the 2009 owner's manual, page 3-18 of the 2010 owner's manual, or 2-18 of the 2011 owner's manual. -JFP
