Hi guys, having some problems with my vararam (VR-SC1). This is the third time the lower gasket has shifted off of the bottom assembly. I'm worried because who knows what kind of debris can get caught in the filter or directly in the airflow.
This is the third gasket I've used (all from Vararam). The first time I tried fixing the gasket with all sorts of stuff including Gorilla Glue... no luck, it still managed to slide off..
I'm guessing the reason it slides off is because of the pressure thats applied when clamping the upper half down to get the rubber latches secured.. not really sure.. I'm gonna send Vararam a polite email to see if I can get a couple more gaskets.
KnobJockey: I never thought to remove the adhesive before gluing! Good idea, thanks. And yes, I'm quite confident vararam will take care of me. I took a peak at the install instructions on their site to refresh my memory, and they do state to put the unit together before putting it in the car so it aligns better. It's just hell of a lot easier to only remove the top half when I clean the filter.
Has anyone notice that the gasket bends a little bit in the upper half? Might be a result of me muscling it into place, but found it a little odd. I'll post a pic when I get a chance.
This is one reason I gave up on my Vararam, just to many hassles to get it to secure properly. In the end I believe I accomplished the task but I was always not fully secure in the knowledge that it was doing its job, and a pain to take off the car to check! I believe the system gives results but in the end I came to the conclusion I did not need the improvements.
Mine looked like that when I first pulled it apart(PO put the unit on) to clean the element.
I gingerly removed the gasket, warmed it in water so it would return to it's original shape. Then completely removed that clear film left behind, clean the surface with alcohol, then re-applied the gasket with 3M weatherstrip adhesive.
Problem solved.
I recently spoke to Vararam, thier fix is very similar. Bad design? Maybe. However, I lean toward one of the better designs available for the C6 simply because it pulls fresh, cool air while most others can suck air from within the engine bay. There is a noticeable difference in boost when the temp gets below 70 degrees or so, just as an example.
BTW - Vararam did confirm that putting a tag in front/center of the C6 grill, blocking air to the intake, does indeed affect the performance of the unit. I believe the analogy they used was the tape NASCAR uses on the front of the cars to block air.
The Vararam folks were excellent. I did the same thing removing the old gaskets and cleaning my filter. I do it every spring. I don't think it's a bad design though. But if they had put a 3/16" dia. groove all around the lower section. Then all you'd need is a 3/16" dia. rubber , like you use on a screen window, and then the seal would be nested and wouldn't move when the upper half clamped on it. Maybe the next generation will use that concept. It wouldn't cost any more in the mold either.
Problem solved.
I did something simular with 3M contact adhesive, coat each side, let get tackie and place together and let dry. lasts a long time!!!!
