changing shift knob aut4 for sequential
Old Sep 26, 2011 | 01:52 PM
ivan(choriquesos)'s Avatar
ivan(choriquesos)
1st Gear
Default changing shift **** aut4 for sequential
hi good afternoon ..
I bought a 2005 c6 aut. and has the square shifter **** .. and wanted to change by 2006. which is a round **** that I like more ..
at the store told me that one can not but I have seen that if you can put .. what is not is like ..
you can help me if anyone has had the same problem as me.?
a greeting.
ivan.
Old Sep 26, 2011 | 02:38 PM
EVRose's Avatar
EVRose
As far as I know you need to replace the entire shifter to get the '06 **** to fit in an '05. I've seen that done.
Old Sep 26, 2011 | 03:21 PM
chriscable34's Avatar
chriscable34
I wanted to change mine but I just painted my push button black for now. I am going to work on a aftermarket **** **** for the 05. I have an idea and the tools to do it, just not the energy to make it happen. Have to get motivated.
Old Sep 26, 2011 | 03:29 PM
EVRose's Avatar
EVRose
Here's what I did.
Old Sep 27, 2011 | 03:38 AM
Z16chevelleguy's Avatar
Z16chevelleguy
They make an adapter that will let you use different ***** on C5s and 2005 C6 with A4.The shifter to **** connection is completely different for an A4 and A6. There is no way without converting a C6 shifter into a a C5. You would have to switch out a handle from a A6 into the A4.It can be done but kind of expensive. The adapter is called a CAU A4 Shift Adapter.You then can buy almost any standard ****.
To changing shift knob aut4 for sequential
