Fuel Smell & The Stealership
So after replacing the gas cap with an OEM one, I'm still getting a smell of gas in the garage from the fuel door and the rear wheel well area. Took the liners off and looked around but couldn't find anything concrete, so I had to suck it up and take it to the stealership this morning.
They said they could smell it too and would try to figure out what the issue is and get back with me. I'm crossing my fingers that it's just a worn hose with pinhole leaks in it, or something equally easy to fix because I really don't feel like paying out the nose to replace something crazy like a fuel tank.
Received 2,887 Likes
I am in the same boat. When I filled it up the smell came back.
Have not decided which dealer to take it to. Not sure who has the best vette mechanic. I am leaning towards Classic Chevy but it is a long drive from my house. Guess I could get a rental.
Let us know what the find out. Good luck.
Damnit Damnit Damnit. They found a leak coming from the top of the fuel tank on the driver's side, but weren't sure yet whether it was the tank itself, the gasket, or a hose. They are doing a bit more detective work before they give me a quote, but said they would more than likely have to drop the exhaust and the transmission in order to drop the tanks to get to the area that needs fixing.
I have an 08 A6, but I thought you could go behind the wheels to do this work without having to drop all those other parts first.
How bad is my pocketbook going to take a beating? I'm pissed at my used car dealer (again) because when I bought the car they told me the factory warranty would expire in October of 2011 (didn't have their facts straight or lied to me), but the dealer records show that the warranty expired in July of 2010.
Received 2,051 Likes
St. Jude Donor '13
Wow, a used car salesman lied to a customer? Whoodathunkit?
Seriously, sorry for your problem. It could happen to me.
Removing and replacing the tanks is big bucks all by itself, plus whatever extra work needs to be done. But do check into that emissions warranty issue.
Chalk it up.
Gas fumes are very flamable; You caught this early.
I always look at worse case; if it was a fireball, ins, company would give u depreciated value which is worse hit. They will make it brand new and u will only smell "new plastic/rubber smell" like factory fresh. Keep that invoice and when you sell, new owner will know its rock solid.
Chalk it up.
I'm going through this now. My car is the same as yours and has the same problem. It has been a nightmare dealing with the service writer at the dealership. The cost of the tank is $960.00 they are charging me 11.1 hours at $105.00 an hour plus tax (does not matter if the mechanic does it faster the dealer charges what the book says, as I'm told by the Service Manager). There is a small separation of caulking where the fuel pump sits in the tank that caused my leak. I feel this is a defect, but I'm the only one who does according to the dealer. GM did pay for the parts, that started out at $1400.00 and has been reduced to $960.00 (Tank only) seems service writer was adding things that I didn't need, but I'm still paying the $1100.00 plus tax. I will post more on this when I get the car back this week. My bumper to bumper warranty had expired by 10 days when I noticed the leak, that is why GM is paying for parts only.
Laura, the Customer Service Rep. that is on the Forum is Great! She did assist me with the problem...It's a shame she is not working at the dealerships too............
Yeah, after this venture, I've decided that I'm NEVER buying a used car again. It cost me about 5k worth of engine parts and labor to get everything fixed on the front end, and I'd wager this will cost me upwards of 2k this time around and I've only owned the car since July. It's been royally dissappointing to say the least.
Yup...same problem I had. I would push for trying to get it fixed under emissions warranty as fuel vapors are emission related. Worse case get them to pick up some of the labor. I had an independent do mine on jack stands only dropping the exhaust in 1 hour on my M6 Z.
Not looking good for me, as my bumper to bumper is over.
Laura could this be covered under emissions warranty?
Need to take mine in to dealer in the morning.
No, I purchased my car at a used car dealership that is in Webster, TX near where I live. I do have a question though as I've done some literature studying since earlier today. It looks like GM offers an extended warranty schedule on some of the emissions related parts (mentioned on p.22 of the 2008 Corvette Warranty Manual). It then goes on to list various parts that fall under the "Emission Limited Warranty" and also the "Emission Select Component Ltd Warranty". I haven't received full details from Norman Frede Chevrolet in Webster yet about my car, but the leak is related to the fuel tank which DOES fall under that select component list according to my literature. Do you think there is a chance that this could be covered for me, and if so, what should I tell the service manager there?
Thank you!
-Jeff
GM just covered my girlfriend's 2007 Denali fuel pump replacement 100% on her 5year-100k warranty, I think...It may have been an emissions issue...I will check and see.
