lug nuts
Old Sep 29, 2011 | 12:32 PM
1911colt's Avatar
1911colt
Default lug nuts
Could someone be kind enough to tell me what the lug nuts on my '09 should be torqued to?I have the chrome "Gumby" wheels.Looked for it in the owners manual but couldn't find it...... Thanks for your help!
Old Sep 29, 2011 | 12:42 PM
wysiwyg's Avatar
wysiwyg
100 ft-lbs
Old Sep 29, 2011 | 12:56 PM
cclive's Avatar
cclive
Old Sep 29, 2011 | 12:58 PM
GOLD72's Avatar
GOLD72
Originally Posted by wysiwyg
100 ft-lbs
Old Sep 29, 2011 | 12:59 PM
Larry/car's Avatar
Larry/car
It is in the manual. Try looking at the specifications section.
Old Sep 29, 2011 | 01:14 PM
Wayne88's Avatar
Wayne88
100 ft-lbs
But in over 40 years of messing around with cars I've always tightened them by hand, without a torque wrench.
I never heard of a wheel falling off because the lug nuts fell off.
Old Sep 29, 2011 | 02:04 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Tighten and torque them with the car off the ground.
The wheels are lug-centric.
Old Sep 29, 2011 | 02:15 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Falling off isn't the sneaky issue. Non-consistent or improper torque of the bolts can warp the rotors.
Elmer
Old Sep 29, 2011 | 02:32 PM
PHXAZ06's Avatar
PHXAZ06
Elmer
And/or the wheel
Old Sep 29, 2011 | 04:22 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
The 100 lb/ft is for dry- no oil, antiseize, etc.
Old Sep 29, 2011 | 04:56 PM
ohmy's Avatar
ohmy
me too...
Elmer
did you ever see how they do it at the dealership or a tire store? air gun set to 200, star pattern optional...
Old Sep 29, 2011 | 05:17 PM
C8-Vette's Avatar
C8-Vette
Originally Posted by ohmy
me too...
Did you ever see how they do it at the dealership or a tire store? air gun set to 200, star pattern optional...
Did you ever try removing lug nut by hand with a bar wrench that were torqued to 200 lbs plus? Amost impossible without destroying the wrench.
As for hand tight, you got to be nuts!!
Old Sep 29, 2011 | 07:11 PM
R50THC5's Avatar
R50THC5
Just had to deal with that today left front wheel . Was a bit pi$$ed but broke the lugs free and then re trq 100 lbs as abv said
Old Sep 29, 2011 | 07:38 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Just don't use JB Weld when you re install as a thread lube ................
Old Sep 29, 2011 | 08:37 PM
Honch's Avatar
Honch
me too...
Yes and on the end of the gun is most likely an item called a torque stick which limits the impact action of the gun to a specific torque. Arguably not the best way of measuring torque but not the same as a uncontrolled impact gun.
ARP (the racing fastener company) notes that the ability of a fastener material to rebound (like a spring) is what really provides the clamping force. Different materials tend to react differently to these conditions. As a result, different fasteners are designed for different tasks.
ARP also states that if a fastener is over-torqued, it stretches too much. Because of this, the yield will have been exceeded, and for all intents and purposes, the fastener is ruined.
When engineers determine torque values they will also take into consideration the expansion of the clamped materials such as an aluminum wheel on a steel rotor. An aluminum wheel that is hot from performance driving or heavy braking will expand causing the bolt to stretch even further.
Why even take the risk when it only takes a few minutes to torque them to their design spec.
Old Sep 29, 2011 | 09:57 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Default Always carry a band aid ..............
And if the screw under yer belly button ever backs out, guess what falls off .........................
Old Sep 29, 2011 | 10:22 PM
ohmy's Avatar
ohmy
that was exactly my point! I once had to use a 4 foot steal pipe at the end of the wrench to get the lug nuts loose, I ended up bending the wrench and yelling at the dealer for doing that to my wheels, not to mention leaving me unable to remove the wheel if need to put the spare on! even though I found this out when changing my brake pads at the comfort of my garage, I was NOT happy... however, the rotors and wheels never warped even with the lug nuts over torqued to the extreme...
you're assuming the dealership knows what they're doing! see my comment above
To lug nuts
