Lost tire key
Old Oct 6, 2011 | 09:00 PM
king off the hill's Avatar
king off the hill
Default Lost tire key
Please whats my best option now ,how do i get them off.
Old Oct 6, 2011 | 09:01 PM
R&L's C6's Avatar
R&L's C6
I bet discount tire or some other tire shop would have the answer.
Old Oct 6, 2011 | 09:02 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Just do like any two bit theif will do. Go to the auto parts store and buy a handfull of the cheapest sockets you can find that will fit the lugs and hammer one on each of the lock lugs. You can then remove the lock lug with a socket wrench.
Old Oct 6, 2011 | 09:04 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
What he said !
Old Oct 6, 2011 | 09:07 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Most tire stores have a wheel lock removal tool set. There are different sizes of sockets to fit the locks. You have to drive them on and use an air gun to remove them. It is easy!!
Old Oct 6, 2011 | 09:35 PM
VET4LES's Avatar
VET4LES
My shop showed me theirs. It cuts the lug nut so they will need replacing.
Old Oct 6, 2011 | 09:49 PM
greengo's Avatar
greengo
D i s c o u n t t i r e
Old Oct 6, 2011 | 09:59 PM
ssv3's Avatar
ssv3
Tire shops. They will take them off in minutes. I've seen it done.
Old Oct 6, 2011 | 10:35 PM
calemasters's Avatar
calemasters
Just go to an auto parts store and get one of these tools.
Old Oct 6, 2011 | 11:13 PM
txsugar08's Avatar
txsugar08
I have used them before.
Old Oct 6, 2011 | 11:34 PM
Rocketmanwpb's Avatar
Rocketmanwpb
Routine for any tire dealer or the dealer to remove tire locks without the key. They have a tool that will cut it off with out damaging the lug.
Old Oct 6, 2011 | 11:39 PM
florida john's Avatar
florida john
Buy another set of the same locking lugs and use key that comes with them.
Old Oct 7, 2011 | 12:33 AM
bearphoto's Avatar
bearphoto
SoCal Events Coordinator
St. Jude Donor '12
Your wheel locks are pretty much a waste of money to put on. As you can see, anyone can get the tool at a local auto parts store to take them off.
Old Oct 7, 2011 | 09:33 AM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
What he said ! On OE wheels, they are simply a way for the dealer to bump up his bottom line. And, the first question To ask when buying aftermarket rims: "Will my original lug nut work ?" Aftermarket lug nuts are a money maker for the tire shops.
Old Oct 7, 2011 | 09:39 AM
Crowhater's Avatar
Crowhater
if all else fails you can weld a nut to your lug nut. Put a nut on the end of your lug and weld in the center of the nut.
PS: disconnect your + battery cable before welding on your car!!!!!!!!
Old Oct 7, 2011 | 09:52 AM
Ghost 23's Avatar
Ghost 23
McGard and Gorilla have key codes; they can replace the key. Do you have the code anywhere?
To Lost tire key
