Try contacting Coastal Tech and see if they have any resellers in your area. If not, take the install instructions to a couple of the top rated car audio shops in your area and feel them out. Any car audio guy worth his salt will have no problem installing it. A shop with experience working on C6's would be preferable as well.
Thanks Tim. I stopped by one of the two installers in my small town and they won't do it. Good idea about contacting Coastal Tech. I will do that.
I could understand if they said they would not warranty the work based on it being a aftermarket part, but to turn away business on a fairly simple install for a pro seems dumb. I guess they must have more business than they can handle or they don't like making money.
Actually in the nyc area I had the same problem 2-3 that I saw looked at me like I had 2 heads..gona keep looking but I will call them maybe they know someone that will do it?
That amazes me... If either of you have problems getting a response from Coastal let me know and I will see if I can get the answer for you.
They are located here in Florida and I had the pleasure of meeting the owner and one of his programmers last week. They came and worked on my car because I was having a issue. It turns out the camera I bought was causing a problem.
