Trunk opens by itself ???
Old Oct 9, 2011 | 03:51 AM
SmoothBen's Avatar
SmoothBen
Default Trunk opens by itself ???
When I lock the door with the door button as soon as i get out and close the door the trunk opens, reclose the trunk and reopen again. The car battery is new from this spring. Never had issues before but started to to this since 2 weeks.
Old Oct 9, 2011 | 11:11 AM
Kenny94945's Avatar
Kenny94945
Best guess....truck release button on FOB or dash is sticking or trunk release on FOB is accidentally pressed while in your pockets (maybe against another set of keys).
(Does the trunk open normally using the dash or FOB buttons?)
Second guess...low battery in FOB.
You may wish to experiment with auto unlock and lock setup in the DIC setup (see you owners manual) to make sure other systems are functioning properly.
Old Oct 9, 2011 | 11:21 AM
SmoothBen's Avatar
SmoothBen
yeah the trunk opens with the FOB and THe button in the car. THe fob is 6 years old maybe its time to replace the battery too
Old Oct 9, 2011 | 01:15 PM
R&L's C6's Avatar
R&L's C6
Maybe also try cleaning the button above your license plate. Mine was sticking when pushed in, I just cleaned it and it works like a champ now.
http://forums.corvetteforum.com/c6-c...-pictures.html
Old Oct 9, 2011 | 01:16 PM
SmoothBen's Avatar
SmoothBen
thanks for the info guys, gonna change my fob battery since this is a cheap fix. Gonna check if it stills pops out
To Trunk opens by itself ???
