C6 clicking in dash?
recently purchased a used 05 coupe, and noticed the other day when I used the turn signals, or after depressing brkae, there was a clicking in the dash to follow, and on another occasion, the clicking in the dash was for no reason, just an on off . Sounds like a selenoid click or something ? I purchased at a non chevy dealer and dropped it off last night, looking for diagnosis in the event they cant help?? Thanks
clicking
C3&C6vettes,
You mentioned you purchased your vehicle from a non Chevy dealership. Is that the dealership you took it into to be checked out at?
Chevrolet Customer Service,
Justin
Justin
Of course they said they will see what they can do .."But we arent a Chevy Dealer"...thats why i wanted to see if any one has had the same problem to give them some advise if need be.
My 08 has done that a few times in the past year. I wear hearing aids so it hard for me to find it. Each time I turned the radio down/off to hear it, it seemed to get rid of it. Later! Frank
My 2009 and now 2012 GS does the same thing. What you are hearing is coming from the passenger side behind the floor board, and it is a solinoid (?) clicking. I brought my 2009 into my local chevy dealer and they replaced it with another one that did the same thing. Suggested maybe more insulation would quiet the sound. The clicking happens when you press the brake.
I only hear it when the car is running and the transmission is in Park. Once I put it in any gear, it goes away.
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
the brake relay is a normal sound only when you hit the brakes and it comes from under the passenger side floor board. the op clearly stated that it was coming from the dash when he used the turn signals. i'm astonished that no one else knows what this is. for me it was a broken hatch release button at the rear of the car (the exterior switch near the license plate). once that was replaced the relay clicking was resolved. even the dealer was stumped. i figured it out myself. i have replaced that switch twice now. its about 10 dollars and apparently a poor design because it gets wet and fails. try here....
Now i gotta hit up the search function again and find out how to take the assembly apart to replace it. This sound is freaking annoying when ever I ride in her vette, although she tunes it out now.
You know I know we are not supposed to be a-holes and reply with "You should have done a search" and so on, but this is probably the most talked about subject on any forum anywhere. This is one of those facepalm moments where I believe that we should actually free up the ones and zeros and remove the search button. Maybe we can substitute it for a **** button. It would finally get used then. Otherwise, its a waste.
When my 07 A6 is in Park, engine running, and I press the brake pedal I hear a click which I believe is a solenoid unlocking the shifter mechanism. If I rest my hand on the shifter and just touch the release trigger I can feel it unlock simultaneous with the click. Seems completely normal to me, but others may not have experienced it with their C6's.
Tom
Tom
The clicking I am referring to is random, while driving, could be sitting at a stop light with foot on brake and "click click click click" about 10 times in a row, or could be driving down the hwy at 80 and tap the brakes to turn off cruise control and click click click click click again, much more annoying than what most people refer to when they talk about clicking in the dash area.
if you read this post or you did a search on his particular problem you would realize that the typical brake relay which is beat to death is not his issue here. in his defense the search function on this forum turns up more crap than anything else. google provides better search results linked to this forum than the actual forum search function. go figure. when i had this issue all that turned up in the search was what everyone else thinks is a normal brake relay click.
Tom
Tom
http://forums.corvetteforum.com/c6-c...post1570084813
It will be a couple weeks until I am home and can mess with it but a new switch will be waiting for me when I get there lol, already ordered it. I'll let you know how it goes.
