I have observed the DIC voltage and used a voltmeter to measure the voltage at the battery, and the DIC normally reads about .5 V less than at the battery terminals.
My DIC voltage is around 13.9v at idle with the battery fully charged.
While driving, the voltage runs as high as 14.2 to 14.4v.
Thank you , I had a problem about a week ago. The car slow cranked and i had to have it jumped. The car sat for one day then I brought it into the dealer to be checked out. On the way there during the day no radio ,light etc. everything off the volt steadily dropped from 14- 13.8 range down to 12.2. this was a highway ride about 20 min at around 55- 70 mph. Car had a check engine light on. {I made a post about needing a new dealer.}
The tech claims light was a crank sensor error. They cleared the code and told me nothing was wrong and the car checked out to spec. I said it's not possible etc. I have only been taking the car out during the day and watching the voltmeter..its all over the place nothing above 13 volts after 10 min of the car running. i'ts in 12.2- 12.8. long story short car had a ruff start again tonight, but it turned over. Car was running ruff also. I plan on bringing the car someplace else. Has anyone used robert chevrolet in hicksville?, they are close to my office. I think my car needs a new battery. p.s its a 2011 grandsport with 2,500 miles.
I thought the alternator also or the battery. They assured me it was charging properly. Im not one to bash about little things but this is auto mechanics 101. Dealer dropped the ball on my previous visit for different repair, and the staff went out of there way to correct there problems. Gave free oil change next visit etc. But I would just like the car repaired properly the first time. It's frustrating as for last 10 years I have been lucky that none of my other vettes have had to go into the dealers for any repairs and A brand new car has had to go in twice in 2,500 miles.
Thanks guys everyone is confirming my thoughts on the problem. This should have been fixed the first time. The dealer tech was telling me that the sub 13 volt range to 12.2 is normal, I disagreed. Anyway thanks to all that have responded.
KABAL182,
I'm sorry to hear you're having problems with your car. I'd suggest taking it to the dealership and having them run some diagnostics to check out your battery and alternator if you're concerned. If you need help locating a dealership or setting up and appointment let me know.
Chevrolet Customer Service,
Justin
Originally Posted by KABAL182
What range does your voltmeter read while driving normally, and say constant speed highway driving?
