Climate Control Problem
Old Oct 17, 2011 | 09:14 PM
Mr. Motion's Avatar
Mr. Motion
Default Climate Control Problem
I just got my C6 back from the local body shop that did some paint work on it. I now notice that the vent controls are not working properly. When I manually set it to blow out of the dash vents, it blows from the floor vents instead. When I then try to set it to blow from the floor vents, the air comes out of the dash vents! Similar story when I set it to defrost. The battery was dead when I picked it up from the body shop and I needed to have it boost. I'm wondering if something needs to be reset and if so, how? I had to reset the power windows to make them close properly, but there is nothing listed in the owners manual about resetting the climate control system.
Old Oct 18, 2011 | 10:57 AM
Gary '09 C6's Avatar
Gary '09 C6
first have the battery fully charged-up...then try disconnecting one of the battery cables for about 1 minute to re-set the system...
you'll also need to re-index your windows again.
