Pics needed of being lowered with cut spring bolts or removed.
Please post your pics.Im thinking about cutting to the last rib on my spring bolts.I did this on my c5 but want to know how it would look on the c6.Currently i have z06 shocks,z51 sways.
How was your alignment too as im using the pfat street specs?
Thank you kindly,
Mikey
Thank you kindly,
Mikey
http://forums.corvetteforum.com/c6-c...asier-way.html
not really understanding your question...
Your car has lowering bolts from the factory. Just turn them counter clockwise. You will see the bushing we are speaking about when you look at it.
your car has a leaf spring not coil springs.
so i will be able to lower my car with the stock bolts?
mostly i regret cuting the bushing in the rear, i have a bad driveway, it is fine on the roads
but looks better, i would not recomend cutting , just lower it
i am going to raise it a little
Yes you can - but the bushings ( a thick tough rubber pad) on the bottom of the OEM bolts are so thick such that you may not be able to get the car as low as you might like - many want to go lower and therefore they cut some of the bushing off...
how low you think it would go without cutting it? i dont wana lower it to to much since scraping the front is an issure here in miami
In my experience and in seeing what others have done here on the Forum, the OEM front bolts will get the car as low as most need. The rear OEM bolts don't go down as far as most people like and that's why they cut the bushings down a bit...
http://forums.corvetteforum.com/c6-c...hlight=hardbar
Have a look at the attached thread - it shows the difference between the thicker OEM bolt\bushing and an aftermarket bolt...
