ECM Install
Old Oct 22, 2011 | 04:51 PM
dwat8841's Avatar
dwat8841
Default ECM Install
Bought a new ECM and sent it to Chuck CoW. Received this week. Went to install, removed the inner fender covers and can see the ECM but can not get to it. Does the front fender have to come off to change the ECM? How difficult is that task? Thanks!!!
Old Oct 22, 2011 | 05:42 PM
RULEMKR's Avatar
RULEMKR
St. Jude Donor '09
http://forums.corvetteforum.com/c6-c...very-easy.html
Old Oct 22, 2011 | 06:36 PM
dwat8841's Avatar
dwat8841
Originally Posted by RULEMKR
The PCM has a latch type connection on it. You will have to lift the
lever to dislodge the connectors. The PCM is not hard to remove
just take your time. If you have'nt done it already; disconnect battery
before you remove PCM.
Thanks RULEMKR! Unfortunately CoW's website is under repair and can't get to videos. The link you gave is great as well....but, my car is a 2011 GS and the ECM is high up on the inside fender. I can see the unit and could get to the two lower bolts from the bottom but the top two. I'm not sure I have the expertise to remove the fender....
Old Oct 22, 2011 | 09:15 PM
dwat8841's Avatar
dwat8841
Ideas, anyone?
Old Oct 22, 2011 | 11:15 PM
Twisted1's Avatar
Twisted1
No bolts at the top.
Just look up from bottom.
Remove the bolts you can see.
I believe it was 2. Maybe 3,
But anyways.. just take them out, them pull it straight down.
One it is down then remove the 2 cable connectors.
Note one grey ,one black.
Color matches the color of of the connector on the evidence.
Hope that helps.
Don't take the fender off
Twisted1.
Old Oct 27, 2011 | 10:42 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default I bet you're glad you went this way.....
CoW BOOSTER is WELL WORTH THE LABOR AND THE PRICE!
Chuck CoW
To ECM Install
