I'm trying to determine if my trunk pulldown is working. This isn't installed on my 2000 FRC.
I lower the trunk until it is resting on the latch and nothing happens. When I push the trunk until it is almost latched manually, the pulldown 'seems' to work, but I could be pushing until it latched manually. I hear what sounds like a little buzz.
Also helps if a door or window is open, even just cracked. The hatch will drop and latch much easier that way...air pressure inside the car keeps the hatch from closing without a nudge.
With a little practice, you can pull it down hard enough for the latch to catch.
Almost slam it down.
I would be careful doing this...I have seen at least one post/pic here on th CF by someone who did it, and the rear fiberglass/SMC above the fascia cracked quite severely.
I just rest the hatch on the latch mechanism and gently push it down until the latch engages...it then closes by itself.
I would be careful doing this...I have seen at least one post/pic here on the CF by someone who did it, and the rear fiberglass/SMC above the fascia cracked quite severely.
