removing glue..
Old Oct 23, 2011 | 05:04 PM
hig4s's Avatar
hig4s
Default removing glue..
Washing my car for the first time I noticed that on the driver side of the back bumper there is a spot about 6 inches long and 2 inches high with some kind of clear glue.. I assume this is where the previous dealer stuck their emblem. Car was a dealer trade to my dealer.
I have dealt with emblem glue on vehicles before but never on something as flexible as the this. And by flexible I mean both the bumper and the glue. This glue seems much more resistant to being cleaned off than what I have seen before..
Any suggestions?
Old Oct 23, 2011 | 05:09 PM
EVRose's Avatar
EVRose
Most of the time you can just rub it off with your finger but if that doesn't work - GooGone.
Old Oct 23, 2011 | 05:22 PM
CaryBob's Avatar
CaryBob
GooGone or equivalent won't hurt the clearcoat. You might be able to work it off with fingers or a rubber squeegee, especially it it is heated first, then use the citrus degreaser in the residue. Final clean with soap & water. Avoid WD-40.
Old Oct 23, 2011 | 05:53 PM
Don-Vette's Avatar
Don-Vette
WD-40 works very well also.
Old Oct 23, 2011 | 07:18 PM
z06clif's Avatar
z06clif
Any suggestions?
WD-40
Clif
Old Oct 23, 2011 | 07:41 PM
hig4s's Avatar
hig4s
Originally Posted by EVRose
Most of the time you can just rub it off with your fingers . . .
That has been my experience too, but this stuff seemed to be rubbing my fingers off..
I'll look for Goo-Gone
Thanks.
Old Oct 23, 2011 | 09:55 PM
golfaddict's Avatar
golfaddict
4th Gear
Default glue removal
Just rub a thin layer of peanut butter on it, let it sit 2 or 3 minutes and wipe it off. Best thing I have found to remove residual glue and will not harm paint.
Old Oct 23, 2011 | 10:16 PM
cegusa's Avatar
cegusa
Plain or "chunky"? sorry, couldn't resist.
I've used peanut butter as well to remove wax residue on black plastic trim on other cars as well.
Old Oct 24, 2011 | 05:00 AM
CMY SIX's Avatar
CMY SIX
denatured alcohol is the car painters friend, you will find this in ALL paint shops, they use it for all sorts of remjoval and prep work.
Old Oct 24, 2011 | 08:29 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Old Oct 24, 2011 | 08:46 AM
GSRANDY's Avatar
GSRANDY
Try mineral spirits.
Regards,
GSRANDY
Old Oct 24, 2011 | 08:59 AM
johnodrake's Avatar
johnodrake
Moderator
Goof Off, Goo gone, 3M Adhesive remover..... among other things. Don't use MEK
To removing glue..
