automatic electronics questions.
Old Oct 27, 2011 | 08:54 PM
hig4s's Avatar
hig4s
Default automatic electronics questions.
I've read the manual and do not see any info that would answer my questions so I will ask them here.
1. The automatic dimming rear view mirror time delay,, any way to adjust it of turn it off? (my old egads!! Ford minivan double egad!! had an adjustment. Yes I use to own a Ford minivan I'm not proud of it.)
It seems on the freeway at night when someone gets right behind me after no one has been there, it takes longer than I like before the system realizes it and dims the mirror.
2. The automatic climate control, is there anyway to leave it on auto without it jumping to max/recirc air when I first start the car just because it is a couple degrees warmer in the car than what I have the temp set at?.
Old Oct 27, 2011 | 09:17 PM
Vette_DD's Avatar
Vette_DD
1. The automatic dimming control does turn on every time you start the car, but you should be able to use the switch on the front of the mirror to turn it off for that duration of the engine running.
2. In AUTO mode, I don't think there's any way to keep the recirc from coming on.
Old Oct 27, 2011 | 10:04 PM
hig4s's Avatar
hig4s
I don't want to turn off the auto dim, I want to turn off the delay..
that is what I figured on the recirc..
Thanks.
Old Oct 27, 2011 | 10:47 PM
EVRose's Avatar
EVRose
It isn't an electronic delay you can adjust. It's an electrochromic process that slowly dims the mirror according to how much light the sensor is detecting. There is a liquid/gel inside the mirror that reacts with the signal from the sensor and actually turns the mirror a shade of green that doesn't reflect light as much.
Old Oct 28, 2011 | 09:11 AM
hig4s's Avatar
hig4s
My old minivan had a sensitivity adjustment for the auto dim.
I just wish at least once it turned it would just stay that way as long as it was dark out.
Old Oct 28, 2011 | 12:09 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
1. Maybe someone can figrue out how to reduce/eliminate the delay, but i haven't heard of it.
2. I've been trying to eliminate that shift into recirc after startup, since the day we got our 2006. Still trying...
But punching off the Recirc button has become almost as automatic to me as fastening the seat belt.
Old Oct 28, 2011 | 02:54 PM
hig4s's Avatar
hig4s
I didn't realized when I bought a new car I would have to reprogram me
I still haven't deleted that try to remove the key from the ignition before opening the door feature from my brain.
To automatic electronics questions.
