2011 MAF Sensor screws
Old Oct 31, 2011 | 09:42 AM
Deftly's Avatar
Deftly
Default 2011 MAF Sensor screws
Anybody know what kind of tool is required to remove the screws from a 2011 MAF? A normal torx bit doesn't work. There seems to be a "pln" in the center of the screw that keeps a torx bit from fitting.
Old Oct 31, 2011 | 09:58 AM
Kiser64's Avatar
Kiser64
St. Jude Donor '12
Probably something like this. Tamper proof Torx.
http://www.amazon.com/Torx-Wrench-Ta.../dp/B0002SQ45K
Old Oct 31, 2011 | 10:08 AM
Deftly's Avatar
Deftly
Thanks, that'll probably do it.
Old Oct 31, 2011 | 12:13 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Once you get those nasty little "tamper-proof' Torx screws out, you might think about replacing them with a couple of stainless standard Torx screws or Phillips screws.
Old Oct 31, 2011 | 12:23 PM
JoesC5's Avatar
JoesC5
Some years C6's had a weird 5 star torx but I believe the 2011 has the standard 6 strar torx with the hole in the end for the security pin.
To 2011 MAF Sensor screws
