Push Start Button Replacement
Old Nov 1, 2011 | 06:41 PM
ricknyc23's Avatar
ricknyc23
Default Push Start Button Replacement
My push start button is a bit worn. is this easy to change? anyone have instructions?
thanks!
Old Nov 1, 2011 | 07:35 PM
Zoxxo's Avatar
Zoxxo
It's *very* easy to change out. Pull off the instrument panel gauge surround in which the switch is mounted and have a look. Use a taped, flat blade screwdriver in the crack at the bottom of the panel (below the switch) to get the thing started without hurting the surround. The panel is held in by clips - you put it back by just snapping it back in.
Z//
Old Nov 1, 2011 | 09:51 PM
tonyasc6's Avatar
tonyasc6
Z//
simple to do. I replaced mine with the painted version when I replaced my gauge cluster bezel that TKO finished in hydrocarbon ...
this may help
http://forums.corvetteforum.com/c6-c...many-pics.html
To Push Start Button Replacement
