Help, question about full length spoiler
Hello, does anyone know where, or if, I can buy a full length spoiler that I dont have to install by drilling additional holes in my car? I would like one that utilizes the pre existing holes in the middle and double sided tape at the ends.
Help would be appreciated.
St. Jude Donor '12-'13-'14-'15-'16-'17-'18,'21
The bolts actually clip on at the ends. You can use the 4 factory holes and leave the bolts off on the ends and use the tape on the ends. I would not and did not do it that way. I drilled the holes. It's no big deal. Most of the spoilers come with a template and your only drilling into plastic. Even if your off a bit everything is covered up by the spoiler.
Mine is a Ron Fellows full length spoiler and I got it already painted and ready to go from Empire Corvettes.
http://www.rpidesigns.com/shop/item.aspx?itemid=1343
2015 C6 of the Year Finalist
Order a painted GM full width spoiler from (Gene)GMPartshouse or (Kevin)PartTaxi. They come with everything you need for installation, including a template if you want to drill holes. As previously mentioned, you have the option to use double sided 3M tape if you do not want to drill the holes. (I would suggest that you do, unless you want to be able to go back to the stock spoiler.)
I did my own installation and it was very easy.
Here is a thread with info and photos.
http://forums.corvetteforum.com/c6-c...oupe-pics.html
Here is my favorite and you can order it pre-painted to match your Vette and it meets your requirement of no drilling. It's from RPI, a forum vendor. The link is below.
It is what I did and no issues
