Help with Headlights
Old Nov 13, 2011 | 03:52 PM
JohnDS's Avatar
JohnDS
Default Help with Headlights
After trying to replace my low-beam headlamp, and failing. I decided to look in the manual. It says the HID low-beam headlampls should be serviced by the dealer, but gives info on how to replace all of the other lamps.
Mine is a 2005, that has had this bulb burn out several times, so I wanted to do it myself.
Has anyone done this, or know what parts are required?
Thanks,
John
Old Nov 13, 2011 | 05:12 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
use the "Search this Forum" to the right on the main/general forum and type in HID replacement. Lots of information posted.
Old Nov 13, 2011 | 06:08 PM
JoesC5's Avatar
JoesC5
The difficult part is getting the bulbs removed/installed without dropping the two mounting screws. They are a torx head and you need a torx screwdriver with a slim shank and a magnetic tip. Jack the front up, remove the tire and open the top cover by removing the push pins. If you mess up one of the push pins, they are available at you nearest parts house( 1/4")
Old Nov 14, 2011 | 12:03 PM
JohnDS's Avatar
JohnDS
Thank you for your helpful replies.
John
To Help with Headlights
