cannot seem to find any information on the subject, so here goes....
i spent about $45 on an fm modulator plugs into the cig lighter. You can plug your usb or apple directly to this unit and it broadcasts on the frequency you selct. all powered by the cig lighter power. I have used this in other cars, but curious if anybody has a recommendation for the C6 (2006). Tried it in my XC90 Volvo and no go.
I used one similar to what you describe in my base model 07 for my i-pod. It worked fine locally but on the hwy I had to change frequencies at times due to them being already in use in that area. I just got used to it and it wasn't that big of a deal.
I tried these also with very limited success. I finally ordered the PAL-II and installed it in my vert. It is not the greatest but it works well with my iPod, integrates with the HUD and was easy to install. And at ~$185 it was not very expensive.
Definitely recommend the $29 fix from Kawal as well. Plugs in in about 3 minutes and the sound is excellent. No FM static, doesn't require a lighter plug, etc.
He has an 06. If the car didn't come with xm from the factory (like mine ) he may not be able to use the quick connect method.
If the xm component is there
If not, you're looking at spending $190 (for the PAL), removing the center console and plug-in in the PAL to the head unit.
Not sure what information you're looking for? They output the signal via fm. You have to make sure the frequency you select isn't being used. Sometimes, the frequency isn't exactly right, so you have to go up or down an increment on your radio. There really isn't anything car specific to these. Should work on the xc90.
I have one that I use when I'm renting a car (actually, two - one for the Zune and one for the IPod). They do the job, but really don't sound that great.
