I've found that starting the car with the tender attached is not a problem until you put the car in reverse, and back out pulling it out of the wall plug and dragging it with you.
I can see that happening to me, so I always keep the hood cracked open when it's attached.
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
Originally Posted by Glennm27
No harm, but also no reason to do this. If you are leaving the Battery Tender hooked up you are obviously not planning on moving the car, so why start it?
Originally Posted by jimmie jam
it's better not to run it if you are not planning to drive it. I have stored cars for over 35 years and have found that if you are not going to actually DRIVE it up to operating temps, it's better not to run it at all. FWIW.
Originally Posted by johnodrake
Originally Posted by Ed32
Originally Posted by carjo
I agree
Originally Posted by Olddudesrule
Couldn't agree more. Without burning off any moisture or contaminates that have accumulated, you're only adding to the issue. As far as the Tender goes, it wouldn't be harming anything to run the car with it attached. I've used Tenders on every non-daily driver I've owned for the last ten years, and swear by them for extending battery life and helping to eliminate low voltage related issues.
I like to disconnect the battery charger once I start the car. I don't think it will hurt, but I just do. I use the 1.5 amp Schumacher trickle charger if you are interested in one. I got mine at Wally world for about twenty bucks. About half to a third of the Battery Tender and it does the same thing. Plus, I have had a regular Schumacher charger for over 40 years now and it keeps going strong. it's a good brand.
The tender operates at very low voltage however I always disconnect the tender prior to starting the car just to be safe should there be a failure anywhere in the ultra sensitive electronics of the C6. On my midyear I dont worry too much.
I think you meant to say that it operates at a very low amperage. Not voltage, right?..........
I always disconnect tender before starting the engine. It's simple common sense. IMO
...hasn't happened to me yet, but it could anytime now...!
My Schumacher charger worked great for many years until I "accidentally" not only forgot to unplug it but also ran over it with my truck...
Happened to me once during the 23 years I owned my C4. Luckily, the quick-disconnect cord saved me from doing any damage.
Since my new CTEK is plugged into the glovebox 12V outlet of my C6, there's NO WAY that could happen now...FAMOUS LAST WORDS!
Uh........I won't mention the time I did a brake job on a girlfriend's car and when I got done, I tried to back it out of the garage. When I couldn't understand why it wouldn't move in reverse, she pointed out that the front end (with front wheel drive) was still jacked up off of the floor. Oh!! OK!!.............
uh........i won't mention the time i did a brake job on a girlfriend's car and when i got done, i tried to back it out of the garage. When i couldn't understand why it wouldn't move in reverse, she pointed out that the front end (with front wheel drive) was still jacked up off of the floor. Oh!! Ok!!.............
must have been a front wheel drive car, you could not get that lucky with a rear wheel drive IF you did not put blocks under rear wheels.
I use battery tenders on all of my cars, having a stash of extra AC plugs is a smart move because the AC cords have a nasty habit of falling out and getting under the wheel and then deciding to live somewhere else.
