Sharp Turn
Old Nov 24, 2011 | 09:43 PM
CPTAHAB's Avatar
CPTAHAB
Default Sharp Turn
When backing from being parked and making a sharp turn, seems like the front tires are "skipping out". Normal? Also, power steering makes some noise. Thoughts?
Old Nov 24, 2011 | 09:55 PM
hisvett's Avatar
hisvett
St. Jude Donor '14-'15
If you are driving a GS, the front tires are as large as the rears on a base C5. A lot more rubber on the ground so they will tend to bind in a tight slow turn. In the owners manual it will reference the condition, saying it's normal.
You need to post a little more info on your PS.....year of car, fluid level OK, is it old fluid or been on the track (overheated) etc.
Torchsport's Avatar
Torchsport
St. Jude Donor '15 thru '26
Welcome to the world of wide, grippy tires.
Old Nov 24, 2011 | 09:57 PM
hawkgfr's Avatar
hawkgfr
They push like a dump truck.....in parking lots mine will slip right over painted lines. (regular coupe)
Old Nov 24, 2011 | 10:10 PM
surburban99's Avatar
surburban99
I have a C6 coupe, and this happens to me. It is normal for tires this wide to do this.
Old Nov 24, 2011 | 10:33 PM
HummelS's Avatar
HummelS
Definitely feel some "scrubbing" on slow, sharp turns with my GS.
Old Nov 24, 2011 | 10:40 PM
phileaglesfan's Avatar
phileaglesfan
GM cannot do anything to fix the problem, unless they want to put narrow tires on the Vette.
Old Nov 24, 2011 | 10:43 PM
OnPoint's Avatar
OnPoint
The Consigliere
It's normal. Don't fret it.
To Sharp Turn
