DD Mods Kicker Upgrade Write Up
First off open the doors hood and hatch. I disconnected the battery because I did not want to cause a drain. Simple procedure with a 10mm driver pictured here:
I started with the drivers side door. You must first remover the small plate under the arm rest pictured here:
Them remove the 2 screws pictured here using a 30 Torx :
Now time to remove the door panel. I bought this set of panel removers from Harbor Freight for about $6 and it was money well spent as it made the job much easier. Here is what they look like and the Item #:
There are 8 pins holding the door on and metal hangers on top. Don't worry as you are prying the pins loose as it will make a horrible sound. Once the door panel is loose you will have to disconnect this plug pictured here:
Once that plug is disconnected your door panel will be free from the door as pictured here:
Now that your door panel is removed you can install the tweeters in the door panel. There are 4 Phillips screws and a connector plug to remove pictured here:
Now install your Kicker speaker in the door using the supplied Metra harness kit pictured here:
This harness kit is plug & play and is fail proof as there is only 2 wires and they are different sizes + & - as pictured here:
Here is the installed tweeter pictured here
Now you are ready to re-install the door panel. There is a new technique for installing the door panels. Refer to this link:
http://forums.corvetteforum.com/c6-c...ll-method.html
Here is the pictures from my door. I used shoe stings and it worked like a charm
For the passenger door you will have to remove 2 screws. The first location pictured here:
The second one is the door release button pictured here:
Once they are removed follow the same steps as the drivers side door.
On to the back speakers. Support the hatch, even if you do it one side at a time, just one shock can't hold it up. The rope doesn't need to be tight, it just needs to keep the hatch from falling. couldn't find any rope so i just rigged up a extension cord and it worked fine. Pictured here lol:
Pull up the rubber boot at the bottom of one of the shocks. Unplug the rear defogger. Pry out the retaining clip far enough to grab it with a pair of pliers, then pull it out. Push up on the hatch to release the tension on the shock and it will easily slide right off of the mount. Repeat on the other side. Pictured here:
Next Pull out the four push pins at the top edge of the speaker trim plates (two on each side). Kinda hard to see in this picture:
To pull off the trim panel, reach under the front lower corner and pull straight out about 1". You should feel one of the friction clips release. Slide your hand up near the top front corner and pull it out until that clip releases. Undo the four screws holding in and pull out your old speaker. Here is the picture of the new mounted Kicker speaker:
Repeat process for other side. That is basically it.
My initial impression of the speakers:
They will not be any louder but you will notice a big difference in sound. The tweeters bring more crisper highs then the Bose ever did and the rear speakers sound much better as a fill in now. I have a Pioneer X930BT installed which I also bought from Dennis as part of his Rocktober special so I can tweak my sound a little more then the stock Nav unit that was in before. But even with a stock unit you will notice a big difference! I am also adding a box with two Kicker 10's and a amp from Dennis next month which should finished out my sound system. Here are a couple of videos so you can hear what the Kickers sound like:
Rock:
Rap:
Country:
I hope this helps anyone who is on the fence about buying this package
I am very happy with the results and again with the top of the line service Dennis and his company provides for us.
A big Thanks to Dennis @ DD Mods
Always a pleasure working with you.
Talk to you in a few weeks!
Dennis
