2011 Exhaust Tips
Old Dec 4, 2011 | 11:54 PM
Hgreen0814's Avatar
Hgreen0814
NJ Events Coordinator
Default 2011 Exhaust Tips
What is the best cleaning product to use to get the tips back to its original bright shine?
Old Dec 4, 2011 | 11:57 PM
WICKEDFRC's Avatar
WICKEDFRC
There is some type of electric powerball cleaning machine out there. Someone will chime in sooner or later. The photos I seen look great, but since I have long tubes and no cats, I don't care. My exhaust tips look like a chimney stack full of soot.
Old Dec 5, 2011 | 01:04 AM
greengo's Avatar
greengo
Simichrome
Old Dec 5, 2011 | 01:25 AM
mikemc59's Avatar
mikemc59
Cruising
Old Dec 5, 2011 | 02:43 AM
Triumph Jerry's Avatar
Triumph Jerry
Go to your local Harley Davidson shop and get "Harley Bright Metal Polish" for like $6.
It's in a tube like tooth paste, I did all four tips in 15 minutes and they look like new.
Old Dec 5, 2011 | 05:11 AM
obxchartercaptain's Avatar
obxchartercaptain
FL Events Coordinator
I went to Harbor Frieght and picked up some polishing compond and a barrel applicator that goes on a drill. 5 mins on each tip makes it look like a MIRROR. After you use the compound, you need to use a metal polish/sealer to finish the job. Wherever I go people ask ...."how did you get those tips like that"? It also works great on the outside of the exhaust but that takes alot longer.
Old Dec 5, 2011 | 06:06 AM
Don-Vette's Avatar
Don-Vette
Originally Posted by greengo
Simichrome
Old Dec 5, 2011 | 07:07 AM
lastcowboy's Avatar
lastcowboy
go to the hardware store and get a polish rue ,norm .comes in a package 3 sticks and buffer tips ,about 10-15 bucks.........
Old Dec 5, 2011 | 10:51 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Simichrome
The best by far
Old Dec 5, 2011 | 01:24 PM
doubledime's Avatar
doubledime
After polishing my tips I use Glare Polish. It is supposed to withstand up to 500 degrees. I'm no chemist, and I have no way of knowing if this is true, or even if the tips get hotter than 500 degrees, but it seems to work great. After a longer ride, I do try to wipe them off immediately after shutting down, which helps also.
Old Dec 5, 2011 | 02:07 PM
COL-INF's Avatar
COL-INF
See http://www.corvettemods.com/servlet/...exhaust/Detail
Very happy with the results.
Old Dec 5, 2011 | 02:28 PM
ROD BROWN's Avatar
ROD BROWN
Default How do you polish?
My question is how do you polish between the exhaust pipe extensions and the bottom of the car.Is the polishing pads large enough to polish the extensions with out touching the painted areas?
Old Dec 5, 2011 | 02:46 PM
COL-INF's Avatar
COL-INF
Answer: "Very carefully." The polishing bonnets are different diameters and taper so they will work. I use a small aluminium plate that I slip in between the pipes and the painted surfaces.
Just take your time. Obviously easier if you have the vette on a lift.
Old Dec 5, 2011 | 04:49 PM
crazyeddie's Avatar
crazyeddie
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13
I wash my car after every two or three outings. I use a circular brush with soap and water to clean the insides of the pipes and a wash cloth to wipe down the outside of the pipes. Did this on my 2005 and now my 2009 and never really had a need to polish the tips. No Trophies for me!!
eddie
To 2011 Exhaust Tips
