TPMS on custom wheel
Old Dec 5, 2011 | 08:58 AM
chsia's Avatar
chsia
Default TPMS on custom wheel
I am waiting for my 12 GS Centennial to arrive. I am planning to change the tires from 18/19 to 19/20 and getting custom wheels from http://www.bcec.com.tw/wheel/en/cs-fa10.html. Is TPMS part of the OEM valve stem? Can I use TPMS on the custom wheel whose valve stem can be seen at the bottom of the web page ?
Old Dec 11, 2011 | 07:44 AM
chsia's Avatar
chsia
Nobody has the answer?
The custom wheel valve stem is circled in the following pic:
Is the OEM TPMS/valve shaped like to custom wheel one? Just a simple replacement?
Old Dec 11, 2011 | 09:03 AM
BEZ06's Avatar
BEZ06
Here's what the tire pressure sensors look like and how they mount in an OE wheel:
For cosmetic reasons, many of the exotic aftermarket wheels mount the valve stem in some manner like you're talking about.
Because in some aftermarket wheels you can't mount the tire pressure sensor in the manner they're mounted in an OE wheel, it may require that they are mounted with straps/bands (large hose clamp) in the drop center of the wheel, or there are some brackets available to mount them insdie the wheel.
Sometimes this presents problems programming the tire pressure sensors into the TPMS computer memory in the car. The TPMS tool required to trigger the sensor (force it to transmit its data during the programming procedure) has limited range - its antenna must be within a couple inches of the sensor in order to trigger it.
If you do mount the sensors deep inside the wheels with bands or brackets, make sure you mark EXACTLY where they are in the wheel so you can get the antenna of the TPMS tool as close as possible to the sensors when programming them.
Bob
Old Dec 11, 2011 | 10:02 AM
tloon's Avatar
tloon
On my Forgelines there is a bolt mechanism toward the back side of the wheel that you slide the TPMS into and tighten down. The air filler end does not come thru the wheel, but the whole unit just sits inside the tire. Much better than the straps, I have been told by the tech. We put them back on the original locations and they work fine.
Old Dec 11, 2011 | 10:38 AM
BEZ06's Avatar
BEZ06
Here are some solutions for mounting tire pressure sensors in aftermarket wheels.
Below is a bracket. It includes a bent valve stem that sticks out of the wheel, and there's a mounting loop that allows you to bolt the sensor completely inside the wheel:
And below is a link to a banding system:
http://www.revolutionsupply.com/strapkit.aspx
Bob
To TPMS on custom wheel
