Mar 5, 2015, 06:24 PM
See related guides and technical advice from our community experts:
Browse all:
Exterior How-Tos
How do I replace the front emblem??
Dec 11, 2011 | 05:51 PM
Does it just pry up or does it have nuts on the back? My emblem has faded and I have a new one impatiently waiting to go on
Dec 11, 2011 | 05:54 PM
2015 C6 of the Year Finalist
Quote:
Originally Posted by
Vel-Yellowc6
It has 2 pins that help line it up correctly using holes. It is secured by adhesive. Use a heat source (hair dryer) and some dental floss string to work it loose.
No nuts.
Dec 11, 2011 | 05:55 PM
ncvette_1FUNRIDE
I replaced my aluminum one with chrome.
Dec 11, 2011 | 05:58 PM
I used fishing line to cut through the adhesive. Then use Goo Gone to clean the area before you put the new one on.
I went with these
Dec 11, 2011 | 06:04 PM
Née emblem did not come with adhesive. What do I do!?
Dec 11, 2011 | 06:11 PM
Here's what I am about to add.
Dec 11, 2011 | 06:12 PM
Vel-Yellowc6
I'd return it. It should have double sided tape. You could use clear silicone but the tape would be neater.
Dec 11, 2011 | 06:36 PM
3m heavy duty outdoor adheasive tape work great. It has been on mine for over 2 yrs.
Dec 11, 2011 | 07:32 PM
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
I went with these:
Dec 11, 2011 | 07:35 PM
wayback
where did you get that badge?
Dec 11, 2011 | 07:37 PM
deepcj7
pm sent
Dec 13, 2011 | 03:19 AM
Bought it from a forum member... Sadly
Dec 13, 2011 | 09:29 AM
You can pickup the double sided foam tape from autozone in the paint section. Put the tape on the back side of the emblem and use a razor blade to trim the excess. Don't forget to use a solvent to clean the old adhesive off the emblem first. I have used this method many times. Goodluck.
attach ,
c5 ,
c6 ,
change ,
changing ,
chevy ,
corvette ,
custom ,
emblem ,
emblems ,
forum ,
front ,
install ,
replace ,
replacement
