Eng replacement
Old Dec 12, 2011 | 07:24 PM
RT2SJB's Avatar
RT2SJB
Default Eng replacement
I have an 07 A6 with 29K miles on it that has piston slap. Would you leave it alone or let the dealer replace the engine under warranty? Would the new engine reduce the value of the car?
Old Dec 12, 2011 | 07:27 PM
boraxman's Avatar
boraxman
I would let the dealer replace it if they are actually willing. Most dealers will say its normal.
As far as value...its a dime a dozen car so I wouldnt give it much of a thought....JMO.
Old Dec 12, 2011 | 07:28 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
GMs stance on piston slap is that it doesn't hurt anything, but you can try
You really think that the C6 is an investment?
Old Dec 12, 2011 | 07:33 PM
RT2SJB's Avatar
RT2SJB
Ouch, you guys are brutal. Just asking a simple question.
Old Dec 12, 2011 | 07:36 PM
JJC5's Avatar
JJC5
Piston slap is harmless. Leave it alone unless you want a new motor.
Old Dec 12, 2011 | 07:41 PM
boraxman's Avatar
boraxman
Hey I typed with a smile on my face/
So do you have a dealer willing to replace it?
Old Dec 12, 2011 | 07:49 PM
RT2SJB's Avatar
RT2SJB
I think I will be offered that option, I will know tomorrow. This is a slow time of the year at the dealer I think they are looking for work.
Old Dec 12, 2011 | 08:26 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
I'd be willing to bet GM won't approve an engine replace under warranty for piston slap.
LS motors are kinda known for it in the first place and I don't think there's any evidence it shortens the life of the motor (as long as it goes away once things warm up a bit)
Old Dec 12, 2011 | 09:11 PM
mksz51's Avatar
mksz51
Not brutal - they just sound honest to me. Many on this forum overvalue the "originality" issue with these cars. I baby mine but had no problem drilling 6 holes in the rear to mount a ZR1 spoiler.
Old Dec 12, 2011 | 09:24 PM
Snake.Oiler's Avatar
Snake.Oiler
St. Jude Donor '13 thru '20,'22,'24 thru '26
It's most likely fine. My Silverado has had that for 245,000 miles. No problem.
Old Dec 12, 2011 | 10:30 PM
cclive's Avatar
cclive
But eventually that engine is going to fail because of that piston slap...LOL
And I agree and also doubt that GM is going to authorize a new engine for piston slap. Whether the dealership is busy or not is irrelevant. They are not part of the decision process. They will be required to send the old engine back to GM for inspection, so they can't even exaggerate the problem in order to help you out.
Old Dec 12, 2011 | 11:22 PM
Presidentialpawn's Avatar
Presidentialpawn
what is a piston slap?
Old Dec 12, 2011 | 11:58 PM
cclive's Avatar
cclive
It is a noise that sounds like a rattling piston...sort of the same sound that a diesel engine makes. It can be caused by too much clearance in the cylinder and sometimes will go away when the engine warms up and clearances tighten.
Old Dec 13, 2011 | 09:25 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Our 2001 sounded like a diesel for the first couple of minutes after starting, still sounded that way and running perfectly when traded at 66k miles.
Old Dec 13, 2011 | 10:03 PM
GSRANDY's Avatar
GSRANDY
Our 2001 Tahoe has suffered from piston slap for all of it's 73,000 mile life, hasn't hurt a thing. The knocking sound goes away totally in a minute or two.
Regards,
GSRANDY
To Eng replacement
