DIC pod removal
Old Dec 13, 2011 | 09:28 PM
GREENTAHOE's Avatar
GREENTAHOE
Default DIC pod removal
Ive got an 05. Do the pods for the DIC buttons come out on there own or do I need to remove the whole assembly around the steering wheel?
Old Dec 13, 2011 | 09:34 PM
RicK T's Avatar
RicK T
You have to at least undo the cluster so you can get to the 3 screws that hold the pod. Info and pics at the beginning of this DIY:
http://forums.corvetteforum.com/c6-c...many-pics.html
Old Dec 13, 2011 | 11:21 PM
mpuzach's Avatar
mpuzach
If you're trying to remove the silver plastic pods you need to remove the entire assembly. If you're just trying to remove the buttons you can get to them by just pulling the pods away from the dash and then carefully removing the screws that hold the button assemblies in place. Either way, if you use the link that Rick provided you can't miss.
Old Dec 13, 2011 | 11:22 PM
cclive's Avatar
cclive
And something plastic is much more likely to break if it is cold where you are working. The two pods are one piece with the pieces above and below the instruments.
Old Dec 13, 2011 | 11:36 PM
GREENTAHOE's Avatar
GREENTAHOE
Thank you guys!
To DIC pod removal
