HUD problems
Old Dec 19, 2011 | 07:20 PM
Easy Goin's Avatar
Easy Goin
Cruising
Default HUD problems
Does anyone know how to remove the dash bezel for the HUD on an 06? Dumb question, of course someone does. It looks like it just pops off but, I'm a coward. i don't want to break it.
Old Dec 19, 2011 | 07:21 PM
C6ToGo's Avatar
C6ToGo
Push forward toward the windshield to release from its slots.
Old Dec 19, 2011 | 07:33 PM
Easy Goin's Avatar
Easy Goin
Cruising
Thanks!! Kind of what I thought but I wanted to be sure.
Old Dec 19, 2011 | 07:44 PM
Raazor's Avatar
Raazor
Goon Squad King of Battle
St. Jude 15 Year Donor
St. Jude Donor '08 thru '23
/thread
Old Dec 20, 2011 | 01:21 PM
Andrew6@TheDoubleAA's Avatar
0Andrew6@TheDoubleAA
Former Vendor
Houston Events Coordinator
St. Jude Donor '11-'12, '14
I believe in the Beer Fairy
if you're removing old one to put in a new one the easiest way is to have the cluster area opened. Pull down with one hand on back of dash and push forward towards windshield on bezel with the other. It's pretty much held in with pressure and the back clip
Old Dec 20, 2011 | 01:49 PM
CO Lightfoot's Avatar
CO Lightfoot
Originally Posted by Easy Goin
Does anyone know how to remove the dash bezel for the HUD on an 06? Dumb question...
Not a dumb question.
But the real question is, why do you want to remove the bezel?
If you're trying to repair or replace your HUD, well, you can't do it through the bezel opening.
Edit: Let me be clear... the "bezel opening" is on top of the dash -- the HUD image projects thru that opening.
If you're having HUD problems (shaky image, won't adjust, or ?), to fix it you will probably have to replace the HUD. Lots of related threads, like these:
http://forums.corvetteforum.com/c6-c...on-window.html
http://forums.corvetteforum.com/c6-c...e-easiest.html
http://forums.corvetteforum.com/c6-c...my-09-1lt.html
Depending where you're located, Andrew6 or others may be able to help.
Old Dec 20, 2011 | 07:54 PM
Easy Goin's Avatar
Easy Goin
Cruising
I believe you, but it looks like the mirror slipped off the pin. Is there glass in the HUD unit that would prevent me from putting the mirror back in place?
Old Dec 20, 2011 | 08:49 PM
Former Vendor
happens pretty frequently (usually in the '05's),the retainer is plastic and breaks over time. You can either replace the unit itself or just replace the plastic peice with metal so it doesn't happen again.
Old Dec 20, 2011 | 10:10 PM
CO Lightfoot
IIRC, there's no way to repair a HUD by reaching in thru the bezel. And I don't recall anyone ever trying... worst case, you might leave fingerprints on the glass... or, get your hand stuck -- how embarassing would that be?
Anyway, an experienced HUD installer (like Andrew6) can replace your damaged HUD in an hour or two. Or about 8 hours at a dealer because their procedure requires a more involved disassembly.
From another thread, more details on the pivot-that-fails :
Originally Posted by gr86ss
My HUD Reflector pivot also failed. The pivot side (opposite the gear and motor) is a VERY poorly designed thin plastic piece. IMHO, this should have been a powdered metal part or a thicker more rugged plastic. Spent a good 14 hours removing and replacing dash/HUD. I purchased a used unit and checked the pivot and it also was ready to go so beware if you purchase a used unit. I modified the mount point of the reflector pivot with some .015 spring steel that I had in the garage. This is where the HUD reflector will fail and with this side broken the opposite side will also break rendering the HUD unusuable.
I went without my HUD for a couple of months and I'm happy that it's fixed again.
To HUD problems
