Coolant issues
Im from Israel and i impurted my 09 6.2L Corvette from the U.S CA... so far so good , as a part of my first general oil changing i'v bean refered to unproffesinall mechanic
(GM dosnt import that car to here so they wont servise it)
anyhow this unproffecinal guy replaced the coolnet liquids as a part from the service and i guess he just did it worng
or there's very specific way to do it that riquiers specifics tools that he dosnt have
what he did is: draind the water from the radietor and the Condensate tank to replaced them saince then the car suffering from
extreme randoms heat problemes(without any special resone) which will take the heat meter to the red zone very fast (30 sec or soo) we tried to repalce it again and nothing helped
in one point we changed the thermostat which didnt help either i must say tho that by then the car functiend without those issiuse ...
Thx allot
Eddie
The correct antifreeze-coolant mixture is 50% Dex-Cool extended life coolant (orange in color) and 50% (distilled) water. You really do not need any special tools. GM dealers do have tools to do this job, but you can do the job without the special tools. After the coolant overflow reservoir tank is filled to the correct level with a cold engine, allow the engine to idle with the coolant overflow reservoir cap off. Keep aware of the coolant temperature. If the engine does start to over heat, shut it off for a few minutes. As the engine warms up and the thermostat opens, the engine will start to purge the air in the engine cooling system. As the coolant level drops in the coolant reservoir, add more of the 50/50 coolant mixture as required. It helps to do this with the front of the car elevated a little. When you have most of the air out of the cooling system, replace the reservoir cap and drive the car at moderate speeds. For the next few days, check the coolant level in the reservoir frequently. With a cold engine, add more 50/50 coolant mixture as necessary. Repeat this process until all of the air is purged from the engine cooling system. You will know when the air is completely purged because the coolant level in the reservoir will no longer drop.
CAUTION: NEVER OPEN THE CAP ON THE COOLANT RESERVOIR WHEN THE ENGINE IS HOT. Only open when the engine is cool. Open slowly as there is pressure in the system.
Hopefully, this process will solve this issue.
By comparison, Snap-on re-badges the Uview and sells it for $243 and the Vac-N-Fill tool used by GM is $700 to $1000.
http://www.amazon.com/UView-550000-A...4748021&sr=8-1
